Help With TL866 ii Plus on a MAC
pocketscience
261
185
Sydney, Australia
Did you previously use the programmer with a Windows box and the official software? Might need to go back to that to reflash it. I've never run into the problem you have unfortunately.
jajan547
738
296
Houston, Texas, USA
Update I have had success with home-brew and using my Macs now. forgot to update here. I did try to use GUMP as a GUI with the pair and it seems to work okay with reading or verifying chips but when programming I've had a lot of cases with it locking up or crashing, so Ive just stuck with command line for now and have had no issues. home-brew and mini pro on the command line is great.
V.Yakob
119
46
Syktyvkar
When you are too lazy to mess with the terminal window, you can install Windows 7 on a UTM virtual machine and pass the USB.
It works fast even on AppleSilicon-based Mac.
At first I tried to use Windows 10/11, but the performance was terrible, even if you allocate 12 cores.
