How to: Build an External Power Supply for Atari 520ST (Using Parts from Amazon US)
Hurry
This article will detail the steps for building an external power supply for an early model Atari 520ST. There are ways to improve this build with better connectors, and I plan to design and print a 3D printed case for the final product in a future revision. Cases for Amiga power supplies that use similar builds are available on Thingiverse - but unlike the Amiga, the Atari ST doesn't require a power switch on the PSU. I plan to omit the switch on my 3D print design.
Materials Required
Tools Required
  • Multimeter
  • Soldering Iron, Solder, and Flux
  • Cable Strippers
  • Heat Shink Tubing or some hot glue
Build
Step One
Cut the female end from your C13/C14 cable. Expose the three wires and tin (better than I did, ideally).
Step Two
Attach your wires as follows (left to right):
  1. Black to L (Live)
  2. White to N (Neutral)
  3. Green to Symbol (Ground)
Step Three
Plug the power supply in and verify your voltages.
  • +5V should be +5V
  • +V2 should be +12V
  • V3 should be -12V
Step Five
Cut the four conductor cable to length (I cut it to be as long as the C13/C14 side). Cut and strip both ends, the conductor wires, and tin.
For the purposes of this tutorial we will assign the colors as follows:
  • Yellow is +5V
  • Red is +12V
  • White is -12V
  • Black is COM
Step Six
Consult the diagram above When you start to solder wires to the DIN connector, remember that the diagram is oriented as though you are facing the back of the computer, not the front of the DIN connector. Remember to add your heat shrink tubing before you begin to solder.
Step Seven
Bridge the two +5VDC pins with the yellow wire and solder into place.
Step Eight
Bridge the two Ground pins with the black wire and solder into place
Step Nine
Solder Red to +12VDC
Step Ten
Solder White to -12VDC
Step Eleven
Attach the other end of the cable's conductors to the Power Supply as follows (Left to Right):
  • V3 = White (-12V)
  • +V2 = Red (+12V)
  • +COM = Black (Ground)
  • +5V = Yellow (+5V)
Step Twelve
Plug in your power supply and test voltage at the DIN connector to ensure you have continuity and the correct voltage on each pin.
Step Thirteen
Heat your heat shrink or coat the back of your DIN connector in hot glue if you're a savage :) (I suppose a savage wouldn't bother with either... if you are a gentle savage use hot glue)
Step Fourteen
Assemble the DIN connector
Step Fifteen
Test!
Gotta say, i really love the RT-65B - i made a bench supply for testing SE & SE30 logic boards, using one of those. Still keep meaning to get another one to shove into the original Amiga power brick.
Hurry
They really are robust and versatile. I know there are some Cisco switch power supplies out there that offer the same features but sometimes being able to hit Amazon and just say "add to cart" is worth the trouble.
Reactions: KingDingus
rainwarrior
Ontario, Canada
rainwarrior.ca
I made a similar one from an ATX power supply a few years back, but I couldn't find a good DIN connector at the time, sorta had to jury rig something that fit... good to know that they're maybe easier to source now.
jdmcs
TinkerDifferent Board DoP&G
107
71
Central Virginia
DOS Fox told me that the Cisco 34-0874-01 power brick is another candidate for making an Atari 520ST power supply. Might be good to keep in mind if you have friends in IT, or if you have access to a cheap source.
It’s rated for 3A @ 5V, 2A @ 12V, 0.2A @ -12V, and a maximum of 30W. This is higher than the original 520ST power adapter’s specifications.
