IDE/PATA to SATA for iMac G3 rev a
yomatiase
I bought this to add an SSD to my iMac G3 rev a
The SSD is detected if I connect the adaptor to an USB adaptor, but it is not detected when directly connected to the computer.
The same happens to two iMac G4s
Do you know if I need an special specs IDE/PATA to SATA adaptor?
136
Picky as hell is correct. I read somewhere else that you should only use the red boards vs the green ones.
Verify your master slave configuration. It may not be possible to change your master slave on the cdrom (likely your 2nd device), so you may want to consider a 2nd board and swap out the cdrom for a SATA one as well.
446
This correlates with what I have heard - specifically the startech adapters with red pcbs like THIS one.
I have had green ones work before but they are really hit or miss. The majority of them dont work in my macs.
