I am really enjoying the Apple Squeezer especially with the Uthernet Card installed. It works fantastic.
I have ran into an issue that I am going to try and problem solve. When I launch the latest edition of Script Central (2022) I get a bad software, less likely bad memory error. Really interesting. I don't get this issue with the 2021 issue, I run into the problem even if I am trying to run the hypercard sub stacks that the front facing stack pushes too.
I am going to attempt to install the apple squeezer control panel installer and see if I can resolve issues by messing with settings. I am also going to attempt to move the stacks over to a larger hard drive and see if the problem is because of a corrupt disk image.
I also have ran into a bit of a brick wall when it comes to loading webber. It constantly looks for the HTML Tools file...I am going to attempt to transfer that over to my iigs from my Mac. I am not 100% sure how to get this as it seems that Apple has hidden all the old FTP settings from within the System Prefs. I am sure I can muck around and turn it on via command line.
