So I've acquired a Jaz USB Adapter (very cheaply, I should add!) which came with an Iomega 25-pin SCSI adapter. Since SCSI is SCSI and USB is USB, it should work as a generic SCSI to USB adapter, no? However as a test I plugged it into my modern machine connected to a Zip 100 SCSI (with disk inserted) and... nothing. The light on the adapter doesn't even turn on.
Wondering if anyone has used this device before? Is there a trick to it? Maybe a battery inside to switch? Only works on older machines?
Also curious if anyone has the manual and would be willing to scan or photograph it, doesn't seem to be available via Google or on Archive.org.
