Well, at least this makes me feel less crazy!This is crazy. Same computer, disk, memory size, video card, slot D, monitor adapter, and monitor.
Different results
The only known difference is in your parameter RAM. You have a couple of bits set in byte 11 and somehow you've got 32-bit memory set on a 32-bit dirty computer. I assume you have the special memory software (Mode 32, Optima, RAM Doubler, Maxima, Virtual, etc) installed in your System 7 image. (Aside: I set my highlight to invert and I have the same undocumented bit set in byte 1.)
Can you pull the batteries from your IIx to allow parameter RAM to clear out. Then reinstall the batteries and boot directly to 6.0.8 (without first allowing it to boot to System 7.x). That should clear the bits that differ between us.
- David
I pulled the batteries, reinstalled and booted into the disk image you provided: glitch remains.
I jump started it with no batteries installed: glitch remains.
I attempted to manually reset the PRAM from software (opt+cmd+shift open control panel) and restart: glitch remains.
I have previously installed MODE32, but not on the latest 7.1 disk. I last ran a clean install of 7.1 for Mac IIx only, not the universal install. It clearly seems like something is wrong with the PRAM settings, but how to fix it. I will note, I have at least one other board that exhibits the same video issue, I’ll pull it out tonight and verify.
