Looking for some guidance. I have acquired a SE/30 that was sitting in a closet for nearly 25 years. When I first got it, it would simasimac, but cleaning the board of the build up of dust largely resolved boot issues. I was able to boot into the original 40MB SCSI drive. I was also able to boot off of an external disk drive, the internal disk drive needed to be lubricated and cleaned so I never attempted to boot off it before the recap.
After recapping C1, C3, C4, C5, C6, C7, C8, C9, C10, C12 and C13 with Tantalum capacitors the system would boot to a floppy icon with an X. If I connect a disk drive to either the external floppy port or the internal ribbon, the drive head will move and spin even when no disk is inserted. I have tried this with two different drives, one of which worked fine before the recap.
If I boot into the installed OS on the SCSI drive I just get into a loop of seeing "Disk is unreadable" which goes from pointing to the internal drive to an external drive and back again (see video) blocking the system from fully booting up.
Anyone seen anything like this before?
I've read "The Dead Mac Scrolls" and it talks about checking the bourns filter. I checked it and get 50ohms across all pins but ground. No unexpected shorts.
I have noticed a 77ohm short to ground when the system is off on pin 11, 22, 30 and 44 of the SWIM chip but when powered up it gets 5v on those pins. I have also traced all pins from the internal ribbon cable to the pins on the SWIM chip and haven't found any broken traces.
I am a bit stumped, is there any other way to determine of the bourns filter is ok? Is there anything else short of replacing the SWIM chip that I should be looking for?
Thanks!
Thanks!
