Mac Studio Display SE/30: a 3D-printed compact-Mac-style case for a 9.7" iPad LCD
763
I’ve been working on a monitor case for a 9.7" iPad 1/2 LCD that’s meant to look like a thin, futuristic take on the compact Macs. It’s a single ribbon-shaped profile with a chin that steps in under the screen, SE/30-style lines across the front, and a fake floppy slot. Everything fits on a standard 256 x 256 mm print bed. I designed it to print without supports; the only exception is a tiny bit under the end of the floppy slot on the base. The seam between the base and the front frame hides inside the bottom contour line, so you don’t really see it.
I kept the LCD mounting flexible, since panels and their mounting tabs aren’t always in the same place. There’s room around the panel in the frame, four brackets clamp it in, and optional sliding stops (three shapes, depending on where your tabs are) set the height and side-to-side position. I left out any mount for the LCD controller board on purpose, because every one of these boards is different and some come as two or three pieces. The bay behind the screen is open at the bottom. For mine, I printed a little mount for my boards and plan to just glue it to the rear case so the ports are exposed. STLs, a sliced 3MF for the K2 Plus, the CadQuery source and an assembly animation are all up on GitHub: https://github.com/wottle/mac_studio_display_se30
Reactions: iantm
