Macbook Pro/Air - no power
ScutBoy
353
Northfield, MN USA
I've got a couple/three Macbook Pros and Macbook Airs from a local charter school that "don't work", and I offered to give it a shot to see if I can repair.
The common symptom is that none of them will show any signs of powering up, even after SMC reset, disconnecting/reconnecting the battery, removing/replacing the SSD. etc. They do seem to charge their batteries, and SMC reset does show the power light changing as I would expect, but otherwise no dice.
No obvious liquid damage or evidence of drops.
Machines are anywhere from 2013 to 2015.
Any thoughts appreciated!
ScutBoy
353
Northfield, MN USA
With more examination, it seems that when the power is plugged in - or there's charge in the battery - the CPU heats up enough to start the fan, even though the machine is otherwise dead. I will probably pull the logic board to see if I can find any obvious failed components, etc.
