Macintosh 12" RGB Display Repair - Need some help
jibsaramnim
39
26
South Korea
davejansen.com
Hi everyone! I hope you're all having a great MARCHintosh so far!
TL;DR: Trying to repair a 12" RGB Display, not working even after a recap with none of the voltage test points measuring correctly, yet high voltage seemingly working (based on hearing the high voltage startup sound).
Unexpected high-pitched sound coming from T901, though unsure if it's a symptom or "the" problem. Asking for advice on how to best measure my way through finding where likely culprit(s) might exist that prevent the low(er) voltages from working as expected.
I've been working on repairing a Macintosh LC with accompanying monitor that I purchased here in Korea not too long ago that was sold as "for junk" and in non-working state. Both visually looked very clean and not all that yellowed, and the LC's logic board looked very clean too, so I took a gamble on it, even though the asking price was a bit high (par for the course here where I live, sadly). The LC itself is back to life with the exception of sound, which I'm pretty sure is due to the sound chip having gone bad. Hopefully I'll somewhat soon be able to try to fix that last remaining item thanks to a kind soul who may be able to send me a replacement chip. Fingers crossed!
But, onto my main question, and this is related to the Monitor. I purchased the capacitor replacement kit from Console5 and, even though my particular monitor model was ever so slightly different (M1296G vs M1296Z), internally these are identical. I have replaced all capacitors on the main logic board, but have not yet replaced those on the neck board.
After re-capping and doing an initial smoke test, I heard a high-pitched noise, and the monitor's power light did not turn on. I tried to trace down where the noise was coming from, and I'm fairly certain it's coming from T901. I used a sensitive microphone to help pinpoint the origin of the sound — it's not coming from the flyback transformer or tube or so, those are on the other side of the board compared the source of this particular sound I'm referring to.
I'm attaching a (wobbly, apologies) video that captures the sound I'm referring to, alongside with what to my ears sounds like the expected/correct high voltage sound — though please correct me if I'm wrong about that.
I don't know if that component itself is the problem though, or if it's merely a symptom, as when I check for voltages on the test points, none are getting anything remotely close to good readings, only something around or just under 1v. At the same time, it does sound like high voltage is working, or at least I hear the usual high voltage CRT monitor sound when powering on the monitor.
I suspect that there's one or more resistors that might have gone bad, and maybe other components too. I just feel like I'm kind of poking in the dark here as none of the test points measure correctly, and I am not sure where I can and should measure before those test points to find where the likely culprit(s) are. I have gone in and measured various resistors, but without really knowing where to look, I kind of feel like just blindly going around the board is probably not the most productive way of trying to figure this out.
There was some damage caused by leakage in the usual spot, though all traces still check out fine. I did thoroughly clean the whole board, that area in particular, and measured the various components around there that aren't replaced by the kit to see if they still measure OK.
I did find that R534 and R525 were seemingly not measuring correctly. so I have already tried replacing these to see if that made any difference., I did not have 100% exact matching resistors, but they were close enough at least to run a quick test. That made no difference to the results of measuring voltages at all the test points, sadly.
Of course I'll be replacing them with correct resistors, but I need to order those and don't want to do that before knowing which other components I'll be needing to bring this one back alive — if at all possible, of course.
If you have any suggestions as to where I can/should measure or check, please do let me know. It'd be great if I could bring this monitor back alive and use it with the LC.
Thanks so much in advance!
MacMaster
From my past experience with this monitor, focus your attention around C418 near the edge of the board by R534 and R525. Capacitor leakage around this area is probably particularly bad and can cause collateral damage. Check for transistor shorts in this area. I my case Q501 succumbed to cap leakage and needed to be replaced.
What was the condition of the underside of the board in this area?
This was the mess I was dealing with:
jibsaramnim
39
26
South Korea
davejansen.com
Thank you kindly for your reply! That is exactly the area where I focused too, yes. The rest of the board actually looks fine (especially after a clean), but around C419 and R534 and R525 it was quite bad looking. I don't have a better photo of this at the moment, but this is what it looked like when I first opened up this monitor:
Fortunately all traces in the area do still seem to work. I went through this whole section with a multimeter, and all the components that should connect seem to still connect fine. It's entirely possible I missed something of course.
(Guessing you meant T501 here? Edit: My bad, I missed the actual Q501 shown just towards the right of your photo there) I did actually take off this component (Edit: T501, not the one you mentioned) so I could clean underneath too, but I didn't actually test it. I should look up how to test this component with a multimeter, thanks for the pointer here.
Is this particular area a likely suspect as to why I am not measuring any expected voltages on the test points?
Thanks a million!
MacMaster
It's been a few years since I worked on this so I am referencing my old notes. Incidentally, I also got what seemed like a high voltage sound when it was in this clearly broken state but I don't think I got any static electricity popping sounds. I got more distinct static sounds when I got it fully fixed.
In my case the test points were not showing correct voltages:
13v on 80v TP
1.5v on 12v TP
0v on +12v on flyback
I pulled off Q501, Q905, and Q906 and tested them in a cheap transistor tester. Q501 failed testing (indicated as a resistor). I replaced Q501 with this: KSC2383OTA. This restored the voltages and brought my monitor back from the dead.
I also replaced the big resistors at R534 and R525 for good measure even though they seemed fine and bridged between them with a clump of solder instead of relying on the thin trace connecting them on the underside to handle all the current. Your picture shows considerable damage at that trace. These resistors are responsible for baking the capacitors in the area so I also bent them slightly away from the caps (they need to breathe) and placed some Kapton tape as additional shielding on the sides of the caps facing the resistors. The resistors were not the root cause of the voltage failures though, the Q501 transistor was but the hope was doing this would improve longevity.
Your photo is obviously before you started working on it, but make sure all that corrosion is scraped off and you have good copper underneath then mask it over. In my opinion this is the area where your problem is.
Some more photos of my restoration process:
