Here is a list of all the capacitors needed for recapping the 630-0108 240v analog board for the Mac 128k, Mac 512k, and Mac Plus. This analog board can run on either 120v or 240v. It will operate on 120v if wire W12 is in place, and in 240v if wire W12 is removed.
These are the highest quality parts currently in stock w/ Mouser. The list is mostly based off JDW's 120v recap video as there is a lot of overlap in parts with the 120v analog board.
Mouser Cart
Please note that there is no one correct replacement. For example, instead of UPW1V222MHD6, choosing UBT1V222MHD would be a higher quality replacement, but it's currently not in stock. I've listed the rating of the original parts so that you can select a substitute in case something is out of stock. Keep in mind the diameter and lead spacing when ordering outside this provided list.
The three axial capacitors (C5, C10, & C18) are obsolete and no longer produced now, you can use a matching radial capacitor instead.
Attaching images of two boards with original capacitors for reference. Please ping me if you have any suggestions to this list and I will update.
Mouser Cart
Label | Stock Capacitance | Stock Voltage | Replacement Part | Quantity | Notes |
C1 | 3.9uF | 35v | ECW-FD2W395J | 1x | Replace only needed if stock is an electrolytic capacitor |
C2 | 4700uF | 16v | UHE1E472MHD6 | 1x | |
C3 | 220uF | 16v | 860240475007 | 2x | |
C5 | 47uF | 10v | TVX1A470MAD1LS | 1x | |
C6 | 22uF | 50v | UHE1H220MDD | 2x | This replacement is axial instead of the original radial form factor |
C10 | 33uF | 16v | TVX1E330MAD1LS | 2x | |
C11 | 10uF | 160v | UCS2C100MPD | 1x | |
C12 | 22uF | 50v | Same as C6 | ||
C18 | 33uF | 16v | Same as C10 | ||
C24 | 2200uF | 16v | UPW1V222MHD6 | 4x | Use UBT1V222MHD if in stock. |
C27 | 2200uF | 16v | Same as C24 | ||
C28 | 1000uF | 16v | 860240580011 | 1x | |
C30 | 2200uF | 16v | Same as C24 | ||
C31 | 220uF | 16v | Same as C3 | ||
C32 | 2200uF | 16v | Same as C24 | ||
C33 | 4700pF | 250v | C971U472MVWDBA7317 | 2x | |
C34 | 100uF | 200v | UCY2D101MHD3 | 4x | |
C35 | 100uF | 200v | Same as C34 | ||
C36 | 4700pF | 250v | Same as C33 | ||
C37 | 0.47uF | 250v | ECQ-UAAF474K | 1x | Replace only if it is a RIFA capacitor! The original RIFA used was the PME271M647KR30, but replacing it with the suggested Panasonic is better as it will last longer. |
C38 | 100uF | 200v | Same as C34 | ||
C39 | 100uF | 200v | Same as C34 | ||
C42 | 470uF | 10v | 860240375008 | 2x | |
C45 | 470uF | 10v | Same as C42 |
