Macintosh 128k/512k/Plus 240V Analog Board Recap List
Here is a list of all the capacitors needed for recapping the 630-0108 240v analog board for the Mac 128k, Mac 512k, and Mac Plus. This analog board can run on either 120v or 240v. It will operate on 120v if wire W12 is in place, and in 240v if wire W12 is removed.
These are the highest quality parts currently in stock w/ Mouser. The list is mostly based off JDW's 120v recap video as there is a lot of overlap in parts with the 120v analog board.
Mouser Cart 🛒
LabelStock CapacitanceStock VoltageReplacement PartQuantityNotes
C13.9uF35vECW-FD2W395J1xReplace only needed if stock is an electrolytic capacitor
C24700uF16vUHE1E472MHD61x
C3220uF16v8602404750072x
C547uF10vTVX1A470MAD1LS1x
C622uF50vUHE1H220MDD2xThis replacement is axial instead of the original radial form factor
C1033uF16vTVX1E330MAD1LS2x
C1110uF160vUCS2C100MPD1x
C1222uF50vSame as C6
C1833uF16vSame as C10
C242200uF16vUPW1V222MHD64xUse UBT1V222MHD if in stock.
C272200uF16vSame as C24
C281000uF16v8602405800111x
C302200uF16vSame as C24
C31220uF16vSame as C3
C322200uF16vSame as C24
C334700pF250vC971U472MVWDBA73172x
C34100uF200vUCY2D101MHD34x
C35100uF200vSame as C34
C364700pF250vSame as C33
C370.47uF250vECQ-UAAF474K1xReplace only if it is a RIFA capacitor! The original RIFA used was the PME271M647KR30, but replacing it with the suggested Panasonic is better as it will last longer.
C38100uF200vSame as C34
C39100uF200vSame as C34
C42470uF10v8602403750082x
C45470uF10vSame as C42
Please note that there is no one correct replacement. For example, instead of UPW1V222MHD6, choosing UBT1V222MHD would be a higher quality replacement, but it's currently not in stock. I've listed the rating of the original parts so that you can select a substitute in case something is out of stock. Keep in mind the diameter and lead spacing when ordering outside this provided list.
The three axial capacitors (C5, C10, & C18) are obsolete and no longer produced now, you can use a matching radial capacitor instead.
Attaching images of two boards with original capacitors for reference. Please ping me if you have any suggestions to this list and I will update.
  • Mouser Price List Jan 2022.pdf
Elemenoh
413
401
Bay Area
Oh funny I made a similar post at almost the same time. I was considering sharing my Digikey cart, but as you mention availability changes so often. I opted for adding the physical specs instead so someone in the future could find whatever usable options are at the time.
I'll update mine to indicate it's for 630-0102 (the 120V version).
Tony359
25
Swindon, UK
Hello Andy,
Thank you so much for this list!
I am recapping a Plus and I think there is a typo in the list. C11 is listed as 10uF 16V but it should be 10uf 160V - the Mouser link also points to a 160V one.
I hope this helps and thanks again!
Reactions: AndyDiags
Ernesto
Hi, can anyone confirm de correct position of C31? .
I did a recap and it blows of at the first start... checking the board the + is marked over the GND track. That wouldexplain my mistake but the picture posted by the OP shows it soldered tha way.. in my pictureyou can see through the track behind matching (-) to the bigger C30.
This is a Macintosh Plus "international" at 240v.
Thanks...
Ernesto
Thanks...
Ok answering myself. Chequed the schematics and it'son the -12v rail... probably I checked with a tester GND coincidence when soldering and mssplaced it myself.. hope this was for learning
