Macintosh IIfx explosive RAM
Oct 18, 2021
108
225
Ohio, USA
thehouseofmoth.com
Currently in the process of fixing this and very curious, what could cause this in a RAM socket?
Whatever happened blew a hole straight through the board. Leaving one heck of a burn on the case even.
trag
303
151
The 64 pin SIMM socket was also used by Apple for ROM modules and, I think, by Amiga for another type of incompatible memory.
Guessing, someone installed something other than a IIfx SIMM in the socket and caused a dead short from 5V to GND.
Or something close to that.
I have a PM9600 board with a melted DIMM socket and a hole in it, where someone forced 3.3V memory into a 5V slot....
Nice restoration.
Might as well give a few updates on the repair :)
Removed part of the socket, cleaned some debris from the crater.
Pins 1 and 2 no longer exist, 3 is in rough shape. Some traces 2 layers down got destroyed.
Looks like someone shot a Xenomorph next to that IIfx!
Oct 18, 2021
108
225
Ohio, USA
thehouseofmoth.com
Nice restoration.
Hell of a whammy for just 5V but wrong SIMM is the most logical explanation, tnx!
Zane Kaminski
372
615
Columbus, Ohio, USA
Wow, this is an amazing repair. I usually tape down bodge wires against the board with kapton tape. I always thought that was a fairly low-profile solution. I had never considered laminating the repair into the board! Amazing... I have to try your technique of building up the mask goop next time I'm fixing a board with a hole in it.
Oct 18, 2021
108
225
Ohio, USA
thehouseofmoth.com
It’s fun and satisfying! Do share when you get around to it :)
trag
303
151
A bunch more layers on top and the board is whole once again. The two ground pins will be drilled out once the replacement sockets come in or I may just run a wire from the legs to the ground, we'll see.
Would you mind linking to the product you're using to build up mask layer? And is it a UV cure or a two component mask?
That sounds like mighty useful stuff.
Oct 18, 2021
108
225
Ohio, USA
thehouseofmoth.com
Sure thing!
I get the UV curing mask from amazon or ebay, whichever has the best price at the time and brands vary.
Green for the vintage stuff: https://www.amazon.com/dp/B01MUB4PJL
Black for the modern stuff: https://www.ebay.com/itm/PREMIUM-BL...d-UV-Curable-Curing-Solder-Mask-/282637383153
Laser pen to cure it quickly: https://www.ebay.com/itm/UV-Glue-Cu...Laser-Ultraviolet-405nm-Pointer-/132809688246
Note: The black mask takes considerably longer to cure and must be applied much thinner so the UV can penetrate all the way. I also recommend wearing UV blocking glasses unless you're watching your work on a screen through a camera.
GiGaBiTe
34
29
I've had DIMM memory modules get shorted RAM chips that burn pins out in the RAM socket, but never seen one blow a hole in a PCB.
I guess the thicker pins in a SIMM socket facilitate more current being able to pass through the board.
