I could say I wrote this code in a day... But I didn't. I did it in about 4. I made it in 2 attempts. Here is the story:I was waiting to get things for my LCD replacement for the Portable and all of a sudden I was struck by an idea, why not make the keyboard go to USB while you wait? So I did. I took out a sheet of paper that I was working on and drew a rough sketch of the schematic. It all fit together perfectly. Until I could never get the values right. I went with using analogRead, and it never seemed to be good. Until Mr awesome old [probably not] wise guy Techknight says I should use a keyboard matrix! Never had I ever heard of it, so I went in search of a library. And I found a perfect library, the example was exactly what I was looking for. So I installed it with help from Claude and got it working, because it was missing a file and one line of code in it was borked. (everything else was not made by AI) Thankfully I was able to get the matrix down and It now works like a charm! Now to make a case and get it working through ADB and Bluetooth, with it's OG trackball. And incorporate that into the shell as well. What do you think? The one photo with all the resistors is my first attempt. The second attempt doesn't require any resistors at all! Spectacular! (Code and librarys will be uploaded to github shortly)
