GreenBar0n
47
East Bay Area, CA
Good effort. Just remember that any exposed copper needs lacquer applied to it to prevent from further damage.
You can use clear nail polish.
I do have the green UV mask stuff, will put that on the spots I scraped, thanks!
Here's my UE8 bodge wire from Pin 10, this goes to the via under UC8:
Going to need to remove UE8 and get rid of that bodge, or use what's left of the existing trace instead, reason being it causes video distortion, or a bulge where the active display occurs at the left and right borders:
The PO adjusted the picture to maximum size on the CRT, I don't have a trimmer tool that fits the SE/30 opening.
Can anyone recommend the best tool for adjusting the video trimmers on these Mac's?
GreenBar0n
47
East Bay Area, CA
It's not that UE8 bodge wire causing the weird screen distortion in the video above, I just tried SE/30 #2's LB and it's doing the exact same thing. Glad in a way no to have to rework the #1 LB.
Will try an SE AB and CRT tomorrow.
Thinking about getting this trimmer set for adjusting the picture, is there a better choice?
EDIT: Well, this is embarrassing, turns out the video distortion in the video above was caused by the ground strap wire that connects to the CRT screw in the case, the case/bezel hole is stripped and the screw and ground strap were just hanging there disconnected. Connected the ground and the picture is no longer doing that bulge trick. Picture perfect.
