Mid-Budget Oscilloscopes: $150 - $325 Range +- Suggestions?
488
I've been watching the Budget Oscilloscope discussions . . .
. . . but have a problem with spending 10% of the cost of a much more capable medium range O-scope. Budget jobs appear to top out at working with low end computing platforms. Such an "educational tool" might be worth the money, but don't see myself playing around with any system short of the 20MHz IIsi and up to the 40MHz IIfx or even my 110MHz Radius Clone.
Looking at this one as an example:
Whatcha think about scopes in this price range, will they significantly increase the range of systems, maybe even up to the G4 range of processor/bus speeds? Its 7" panel looks to be usable without hooking it up to a computer/display?
607
Well, for under $30, it seems to do what I need. I think I can decode what the pins are on the G5 Quad LCS. This is my first time using a scope, and first time interpreting my results.
This is pin 5, which some claim is 5-12V input. I am going to call it 0-Vmax input, but a typical PWM fan needs 25% to maintain minimum speed, so the 3V I am getting with a slight waveform is about correct for when the computer is idling.
And as I run a CPU benchmark, things heat up, thus requiring the fans/pumps to accelerate...
And at max heat/speed I get this... but when read with a multimeter, I get 11.8V
Pin 1 people seem to have labelled as PWM, but it seems to just be Vmax to me, I saw no waveform whatsoever at any reading. Pretty much the same 11.8V I saw on the multimeter.
Pin 3 is tach output, 3.3Vpp and adjusting the screen to your desired preference was rather easy.
There are lots of youtube videos of this DSO-152 out there, and for the price, I am happy so far. If i need a second channel, that is as easy as ordering a 2nd one for another $30. Yes the test leads are alligator clamps and not a real probe, but you can get adapters.
This Does Not Compute
Emeritus Board Member
373
534
If you can stretch the top end of the budget by $4, you can get a Rigol DHO802:
Like with the previous DS1054z and similar models, it looks like you can flash modified firmware to unlock 100MHz rates:
Also keep an eye on their Clearance page, some good deals pop up there occasionally:
