Disclaimer: a lot of the work described below was done with the help of AI. None of this message was.
Disclaimer 2: first posted on 68kMLA, but I figure it might be of interest on TD as well
After playing with Claude Code to finish recreating old 68k-based Suns (Sun-2 w/ MC68010, Sun-3 w/ MC68020, described on TD as it's not on-topic for 68kMLA), I had an issue: NetBSD/sun3 expects a FPU (unlike SunOS 4.1.1 which can live without). So I needed one, looked at github for all those recreation of MC68881 or MC68882 (well, two of them), and realize they absolutely wouldn't do - not only did Claude find many issues when I asked for a documentation-driven audit, but both of them ended up not fitting (for one by "an order of magnitude"!) in an Artix-7 100T.
So I had to recreate my own MC68881-compatible FPU, the RD68884, with one goal: be small! it needed to fit in the 50T of my IIsiA7 Mini, and even perhaps the 35T in the original IIsiFPGA, and also in a 100T alongside my RD68021 CPU and all the devices in a Sun-3. I wasn't sure if Claude was good enough to do it given the size of the existing implementations, and that I went for the full-fat MC68881 with all the transcendental functions! no cheating by doing the '040 subset and using the FPSP (which was plan B).
Turns out, yes, it works. Claude ultimately (with a bit of help) delivered a design that takes less than 14% of the slices of the A50T... no need to say, I wasn't going for a high-performance FPU
It originally was tested in a Wukong A100T as part of my Sun-3 design, where it was happy to start NetBSD and run hard-float "whetstone" and other FP-testing codes just fine.
I eventually got around to put the RD68884 in the IIsiA7 Mini (standalone, without any other devices yet), and it works! Clocked at 50 MHz, Speedometer 4.02 sees it as roughly the same performance as the 20MHz MC68882 on the PDS adapter... as I said, not fast! But then, a large part of the problem is the overhead of the coprocessor interface anyway.
As far as I know, it's the first "fpga-proven" FPU design to be tested against a real MC68030
