Mystic PPC WITH Apple IIe card
nottomhanks
102
Hello all! I was reading on This Old Mac that the Apple Power Macintosh Upgrade Card for the 575 precludes one from using the LC PDS slot.
BUT….
I thought, what if you used a PDS extension to “raise it up” overtop of the Power Mac card? Would the IIe card be recognized? Would it work?
The answer is YES!!
I’ll be editing a video that documents this, but I was running Total Replay with 7.5.5 with this setup!
Just need to install the Power Macintosh Card control panel, and might need to look at additional cooling, as I have @Kay K.M.Mods Spicy O Clock running at 44Mhz with the help of @JDW suggestion of using OS-CON caps, and I’m also running Mr. Fahrenheit’s VRAM.
Super exciting!!
2,185
I myself don't have one of those PPC cards, but I'm curious if they have an 040 mode. What I do know is the IIe Card requires 24-bit addressing. Normally, you would be using 32-bit addressing to access all of your RAM. That limitation also means that you cannot use System 7.6 or newer as those operating systems force 32-bit addressing to be on all the time.
nottomhanks
102
Yes, that card allows you to boot into 601 mode OR 040 mode. I’m guessing the PPC card will NOT run the IIe card if it requires 32 bit addressing turned on. I actually haven’t installed the Power Macintosh Card control panel yet, so I haven’t actually booted into PPC.
nottomhanks
102
Also, apparently because of the 601 rom limitations, it doesn’t see all of your installed RAM, which is crummy. The 040 recognizes the full 128 Mb, but it takes a while to count it when cold booting.
2,185
@nottomhanks
I am able to boot my PowerMac 9600 into System 7.5.5 even though it has a Buffalo 400MHz G4 (7400) CPU card installed in place of the stock 300MHz 603e CPU card from Apple. So unless your PPC card requires 7.6.x and higher, you should be able to boot into 7.5.5, disable 32-bit addressing and find the IIe Card still works. That is in theory though because no one has yet tested your config. You're breaking new ground!
How much RAM can the PPC card see? 36MB?
Reactions: nottomhanks
2,185
Because of the System 7.5 requirement, I assume you are no longer able to boot into System 7.1 even when you switch over to the 68040 CPU?
BobDaAggie
23
nottomhanks did you ever make that video about the ppc and Apple IIe card? Also where dit you get the odd riser?
nottomhanks
102
Thanks!! It was fun putting that together. You can purchase the 120 pin PDS socket that simply passes the pins through like an extension cord. (Male on bottom, female on top. If you were installing this in a 550/575 you might be able to even use two! With just the one, the IIe card is at a slight angle because there’s not enough room for it to sit flat as it bumps up against the 601 heat sink. I had to CUT the PDS extension so it would match up with the existing connector.
