Need help identifying component in Duo Dock PSU
Newton_Selftest
Hello! I'm new to this forum, so hopefully this is the right place to go :)
I recently picked up a Duo Dock for my Powerbook Duo 250. Its got a Magnetek Power Supply (Model 3359-09-001) in it that has failed, and I was hoping I could get some insight.
When opening up the power supply to identify and replace the caps, I noticed a diode on the board had once gotten extremely hot, to the point of its solder joints melting and deforming. Assuming it had catastrophically failed, I clipped it out to take a look at the part number. Very frustratingly, however, as I removed it, all the identifying markings on it rubbed away into my fingers! So I've come here to ask if any of you folks could help me figure out what the part is so I can find a correct replacement. Here it is:
It's diode number D6. I believe that it got so hot, the printed P/N unbonded with the surface of the diode. The only characters I could make out before they disappeared completely appeared to read "V28", which yields no results online. It was located just under the PSU's fan, right here:
You can see how hot it got just from looking at the board. It's burned on the bottom, too. And since the diode is obviously cooked, I wouldn't count on finding a replacement by testing the old one.
Because of how unique this power supply is (as far as I can tell, it was only used in the Duo Dock) and its strange inconvenient assembly (closed with rivets instead of screws, meaning I had to drill it open) I can hardly find any information on this power supply at all, let alone a datasheet.
So now I'm hoping one of you out there has worked on one of these before and knows what this part could be, or is willing to take a look at their own unit and find out what diode D6 could be.
Any help is appreciated!! Thank you.
470
ISTR there used to be howtos on how to fix the DuoDock PSU tick-of-death? Fixed mine that way ages and ages ago. Thinking it might have been a diode that failed? Falling asleep ATM, but maybe you can search something up about DuoDock PSU Repairs/Failures etc. out on the web?
Newton_Selftest
Firstly, thank you!
I saw that thread before though. Doesn't seem to mention that specific diode, although it does mention a similar one (maybe they're the same? Skeptical though)
The tick of death seems to be related to caps, which I already planned to replace anyway. From what I can tell the diode blowing out on mine is not a common documented problem :/ even if it's a problem caused by caps, I still need to replace this diode since it's definitely been destroyed one way or another.
TheBasement
Launceston, Tasmania
Firstly, thank you!
Hey there, not sure if you’re still searching for this but I’ve got my duo ps apart (2 different ones) so thought I’d post the pictures of that diode.
I can’t make out all of the numbers on it without removing it, but what I can see is BYV28-2(some more numbers but not sure)1332.
Hope that’s some sort of help.
im having no joy at all trying to get a dud one working, replaced the trouble capacitor but still no power at all on the rails.
TheBasement
Swapped one of these from a known working power supply onto my dead one and it did the trick! This is the only place I could find on the internet where someone has mentioned this as a failure instead of all the other posts about the caps. So well done OP sir, you’ve helped me out. And hopefully this thread helps other poor souls in the future. Just for the record my diode/rectifier (thanks for the link Kai) did not appear damaged or overheated. But it tested weird compared to the known working power supply.
Reactions: Kai Robinson
