New Defrag Utility in 2026
2,301
Did you have that on your 2026 bingo card? Now Linux and Mac users can defragment their SD cards for things like FloppyEMU which refuses to work with fragmented files, or BlueSCSI (though @polpo just added FastSeek which means fragmented files are fast regardless on a BlueSCSI/PicoIDE) But you can still if you absolutely need that 1% performance difference. Runs on Linux and macOS.
This is about my 5th attempt to make this utility - and honestly claude got me past the issues I was having in the prior 4 attempts.
I plan to release it opensource after some testers (you) and #MARCHintosh is over.
Give it a try it today! Find the latest downloads attached to this post!
This utility is currently named an uninspiring "fatdefrag" -- maybe that's good enough but I'd like some better ideas!
README:
# fatdefrag
A tool for defragmenting FAT32 and exFAT filesystems on Linux and macOS. Designed for SD cards used with embedded systems (e.g., SDFat library) where fragmented files cause significant performance degradation.
NOTE: This was originally created for BlueSCSI but since release v2026.02.08 is not required any more due to FastSeek by Ian (@polpo).
WARNING: Backup your data before any operation with this tool.
## Why?
When using FAT filesystems on SD cards with embedded devices, fragmented files force the SD card controller to perform multiple seeks through the FAT table, dramatically slowing sequential reads. In addition some devices such as the FloppyEMU can't read fragmented files.
Neither Linux nor macOS has a native FAT defragmentation tool. This project fills that gap.
## Features
- **Check fragmentation**: Analyze files and report extent counts
- **Single-file defrag**: Move a fragmented file to contiguous clusters
- **Full filesystem defrag**: Defragment all fragmented files at once
- **Crash recovery journaling**: Journal-based recovery for interrupted operations
## Portable Binaries
Pre-built x86_64 Linux binaries are available on the [GitHub Releases](https://github.com/erichelgeson/fatdefrag/releases) page. No compilation or dependencies required.
**GUI** (AppImage):
```bash
chmod +x fatdefrag-gui-x86_64.AppImage
./fatdefrag-gui-x86_64.AppImage
# If FUSE is unavailable:
./fatdefrag-gui-x86_64.AppImage --appimage-extract-and-run
**CLI/TUI** (statically linked):
```bash
chmod +x fatdefrag-linux-x86_64
./fatdefrag-linux-x86_64 check /dev/sdX1
**NixOS** users: AppImages require FUSE, which NixOS doesn't provide by default. Use `appimage-run`:
```bash
nix-shell -p appimage-run --run "appimage-run ./fatdefrag-gui-x86_64.AppImage"
## Building from Source
See [BUILDING.md](BUILDING.md) for build instructions, requirements, and portable build details.
## GUI Usage
Launch the GUI with:
```bash
./fatdefrag-gui-linux-x86_64 # or fatdefrag-gui-macOS-aarch64, etc.
**Features:**
- **Drive selector**: Shows only removable FAT32/exFAT drives (protects system drives)
- **Cluster map**: Visual representation of disk layout with real-time animation during defrag
- **Fragmented files list**: Click a file to highlight its clusters on the map
- **Defrag All / Defrag File**: Defragment everything or just selected files
- **Backup warning**: Confirmation dialog before any defrag operation
**Color Legend:**
- Dark blue: Free clusters
- Teal: Used (contiguous) clusters
- Orange/Red: Fragmented clusters
- Yellow pulse: Reading
- Green pulse: Writing
- White border: Selected file's clusters
**Note:** The GUI can enumerate drives without root, but defrag operations require block device access. On Linux, use`sudo` or add your user to the `disk` group. On macOS, the app will prompt for permission automatically.
## TUI Usage
A ncurses Terminal UI (TUI) remenicent of the DOS days.
Launch the TUI with:
```bash
./fatdefrag-tui-linux-x86_64 # or fatdefrag-tui-macOS-aarch64, etc.
**Keyboard Controls:**
| Key | Action |
| `↑/↓` | Change drive selection |
| `A` | Analyze selected drive |
| `D` | Defrag All (after analysis) |
| `S` | Stop current operation |
| `R` | Refresh drive list |
| `Q` | Quit |
**Color Legend:**
- White: Used clusters
- Cyan: Free clusters
- Red: Fragmented clusters
- Yellow: Reading
- Green: Writing
**Note:** Requires block device access. On Linux, use `sudo` or add your user to the `disk` group. On macOS, the app will prompt for permission automatically.
## CLI Usage
```bash
# Analyze entire filesystem
fatdefrag check /dev/sdX1
# Analyze with verbose output (show fragmented files)
fatdefrag check /dev/sdX1 -v
# Check specific file
fatdefrag check /dev/sdX1 -f /path/to/file.bin
# Defragment all files (dry-run first)
fatdefrag defrag /dev/sdX1 -n
# Defragment all fragmented files
# Defragment a specific file
fatdefrag defrag /dev/sdX1 -f /path/to/file.bin
# Copy file contiguously to FAT device (dry-run first)
fatdefrag copy /path/to/source.bin /dev/sdX1:/dest.bin -n
### Options
| Option | Description |
| `-v, --verbose` | Show detailed output |
| `-f, --file <path>` | Specify file path on filesystem |
| `-n, --dry-run` | Don't make changes, show what would be done |
| `-h, --help` | Show help |
## Windows Users
For defragmenting FAT volumes on Windows, try [Defraggler](https://www.ccleaner.com/defraggler).
## License
Copyright (c) 2026 Eric Helgeson. All rights reserved. See [LICENSE](LICENSE) for details.
This project includes vendored third-party libraries under permissive open source licenses. See [THIRD_PARTY_LICENSES](THIRD_PARTY_LICENSES) for details.
And of course it has to have a TUI (Terminal UI) reminiscent of DEFRAG.EXE
  • fatdefrag-macOS-aarch64.zip
  • fatdefrag-linux-x86_64.zip
  • fatdefrag-gui-AppImage.zip
Fizzbinn
295
303
Charlottesville, VA
I humbly suggest "Retrodefragulator" or "Defragulator" for short.
Not sure why but inspired by this old gem that popped into my head when first thinking about it!
Another random thought, "Contiguous"
Going in a different direction...
Fatastic
Fatabulous
Fatdango
The Fat and the Furious
2,223
This is absolutely outstanding. You see, every single time I use my M1 Max 16" MBP to add a new disk image to the SD card of my FloppyEMU, the card gets fragmented. I've spent hours and hours trying nearly everything to prevent the fragmentation, but nothing worked. I don't have this problem so much on my BlueSCSI SD cards because I write new files to existing disk images on the SD via Basilisk II. However, if I add a new disk image (or delete anything), then the same horrid fragmentation happens. It seems to only happen on my M1 MBP, not my Intel Macs. And until now, the only cure was to boot Windows on my old 2015 15" MBP and use Defraggler to defrag the SD card. Thankfully, I no long need to resort to Windoze for that! I have confirmed that the new app by @eric works great to defrag my cards. This software is a real game changer! THANK YOU, ERIC!
Reactions: djc6 and eric
djc6
53
16
Pre-built x86_64 Linux binaries are available on the [GitHub Releases](https://github.com/yourusername/fatdefrag/releases) page. No compilation or dependencies required.
Eric, thank you for this amazing contribution! The URL in the README to download latest binaries seems incorrect - notice the "yourusername" in the URL.
I was hoping to see if an intel binary version for macOS exists.
Thanks!
Reactions: eric
2,223
I tried the following URL variant WITH NO SUCCESS, so @eric needs to edit his earlier post to fix that URL:
Previously, when I was given the opportunity to beta test this software in private, I was able to use the following steps with success when using my Apple Silicon 16" MBP:
  1. I downloaded the software.
  2. I then launched Terminal.
  3. In Terminal, I typed the following WITH A SPACE AT THE END:
    xattr -cr
  4. Then I switched back to the Finder and dragged the file with "fatdefrag-gui" in its name onto the Terminal window, which inserts the path into the command line. After that I pressed return which gave me a new command prompt.
  5. I then copied & pasted the same path and pressed Return, which launched the app:
Sadly, I tried the same steps again just now on my Intel 5K iMac at the office using the Leftmost & Rightmost downloadable files in the opening post, and it doesn't work. I guess that means during the beta test I must have been given a special binary made specifically for my Apple Silicon MBP.
All said, we need a valid URL to download the Binaries so those of us brain-dead to macOS Terminal and dependencies can use the latest version software.
2,301
You described none steps about what "doesn't work". I just downloaded the release on my M3 MBP and it worked (after I did the I'm not paying Apple $100 a year dance). There is no terminal required and no other dependencies required.
djc6
53
16
for me the issue is when I run the binary, I get an error that it’s an ARM processor only binary and won’t run on my 2018 Mac mini (intel based).
I think there is a way to compile applications as a “fat” binary that works on ARM or Intel, that’s why I tried the GitHub link in the README to see if any other builds exist. But the URL doesn’t work.
I’m very excited for this tool to see if it helps with fragmentation issues I’ve had with my FloppyEmu device :) Thank You!
2,301
Ahh - JDW tested on his M-series mac. It has never been built for intel macs. File name gives this away.
Edit: FAT binary attached.
  • fatdefrag-macOS-FAT.zip
2,223
Privately, yes. But if you re-read my post in this thread today, you will see that when I tested it on my Intel 5K iMac today, it didn't work. Just wanted to mention that. That's why I had the same issue as @djc6 .
At work now. No time right now to test your new file. Will later.
djc6
53
16
Eric, thanks for the upload! I was able to execute the GUI, CLI, and TUI versions on my Intel based 2018 Mac Mini running macOS Sequoia 15.7.5 (the latest version this machine is capable of running).
I used the TUI version to successfully defrag a Floppy Emu SD card ! Thank You!
Reactions: JDW and eric
2,223
Intel Mac users, here are the exact steps I use just now to get Eric's Intel Build Attachment to launch on my macOS Monterey 5K iMac:
  1. Launch Terminal
  2. Type the following WITH A SINGLE SPACE AT THE END:
    xattr -cr
  3. Switch to the Finder but keep your Terminal window in view.
  4. After decompressing Eric's ZIP file, drag the file named "fatdefrag-gui-macOS" onto the Terminal window. If you did it correctly, your command line will look like similar to the following, just with a different path:
    xattr -cr /Users/james/Downloads/For\ PM9600/fatdefrag-macOS-FAT/fatdefrag-macOS
  5. Press Return. (That will do nothing other than give you a new command prompt in the Terminal.)
  6. Drag and drop the same "fatdefrag-gui-macOS" onto the Terminal window again, then press Return.
    That launches the app, which looks like this...
It's rather obvious what you must do next. Select your drive (SD card), then use one of the buttons at the bottom left on it. That's it.
NOTE: When you click Analyze, etc., your SD card will be unmounted. This is normal. And when you're done, you just remove your SD card and you don't need to tell macOS to Eject it.
Thanks to Eric for having created Apple Silicon and Intel builds.
This is a FANTASTIC solution to the problems many of us have had with SD card fragmentation. Thank you, @eric!
Reactions: MB.68k and eric
Miles
Thank you for crafting and sharing fatdefrag, Eric.
I often need to defrag ISO files on exFAT-formatted iODD virtual ODDs, which I've had to do under Windows.
Could fatdefrag be extended beyond SD cards to support USB SSDs and HDDs? Under macOS 27.0.1 at least, a FAT32-formatted SD card appeared in the drive list, but not an exFAT-formatted USB SSD.
Looked for the source at https://github.com/erichelgeson/fatdefrag/ as mentioned in the README, but the page is returning a 404 - would you mind sharing it here?
2,301
The GUI/TUI only list disks macOS are marked removable. A USB SSD is likely showing fixed. exFAT is fine. I can change the list to include external disks.
Could you post the output of `diskutil info /dev/disk<#>` for the SSD?
Miles
Thanks for your reply, Eric!
While waiting, I worked with Claude to create an alternative, which successfully defragged a file on an exFAT-formatted USB SSD.
You were right about the USB SSD being identified as "Fixed" rather than "Removable" like the SD card:
Code:
% diskutil info /dev/disk4
   Device Identifier:         disk4
   Device Node:               /dev/disk4
   Whole:                     Yes
   Part of Whole:             disk4
   Device / Media Name:       External HDD
   Volume Name:               Not applicable (no file system)
   Mounted:                   Not applicable (no file system)
   File System:               None
   Content (IOContent):       FDisk_partition_scheme
   OS Can Be Installed:       No
   Media Type:                Generic
   Protocol:                  USB
   SMART Status:              Not Supported
   Disk Size:                 512.1 GB (512110190592 Bytes) (exactly 1000215216 512-Byte-Units)
   Device Block Size:         512 Bytes
   Media OS Use Only:         No
   Media Read-Only:           No
   Volume Read-Only:          Not applicable (no file system)
   Device Location:           External
   Removable Media:           Fixed
   Solid State:               Info not available
   Virtual:                   No
% diskutil info /dev/disk5
   Device Identifier:         disk5
   Device Node:               /dev/disk5
   Whole:                     Yes
   Part of Whole:             disk5
   Device / Media Name:       STORAGE DEVICE
   File System:               None
   Media Type:                Generic
   Protocol:                  USB
   Disk Size:                 2.0 GB (2002780160 Bytes) (exactly 3911680 512-Byte-Units)
   Media Read-Only:           No
   Removable Media:           Removable
   Media Removal:             Software-Activated
   Virtual:                   No
Thank you for the inspiration for both the app and to leverage Claude!
2,301
Ya, that's kinda why I've not published it to github - people these days just say "hey claude build this thing" and don't need to wait a few hours for a person to reply.
Miles
My apologies! But rather than having people waste more CPU cycles having to create a similar app to get work done, why not freely share the code to preserve those precious resources? Your kind clue that "This is about my 5th attempt to make this utility - and honestly claude got me past the issues I was having in the prior 4 attempts." is what inspired me to try it!
