NeXTcube back panel
macaphod
Hello,
I have a defective back panel for my NeXT Cube. The pin 22b of the slot 0 is missing.
Does anyone know what this pin is used for? Anyone know where I could find a back panel as a replacement?
Thanks.
stepleton
Is it necessary to replace the entire backplane for the sake of one missing pin in one connector? If there is someone near you with good equipment for soldering and desoldering, then the NeXTbus connector is a standard DIN 41612 connector so far as I know, and replacements should be easy to source from a major electronic component retailer like Digi-Key or Mouser. There are a lot of pins on the connector (96 of them!), but for a reasonably-skilled and well-equipped hobbyist, extracting the old connector and soldering in a replacement is probably a half-hour job.
macaphod
Well, for sure, this is my second option, but I would prefer to have an unaltered board for this piece of history ;)
Thanks for your offer.
stepleton
This is a peculiar philosophy that I have a hard time relating to --- why is replacing a connector "alteration" while replacing a board in the overall cube is not?
Usage and time cause wear.
I also have what may be some alarming news about the historic 47 uF surface-mount and 220 uF through-hole capacitors on your processor board and (if you have one) sound box circuit board --- as well as (and especially) the 10000 uF ELNA "Long Life" (lol) capacitors on the analog board in your N4000-series monitor (if you have one). You may find that they are leaching a considerable amount of hard-to-repair history all over your hardware as we speak.
PS: Per this pinout page, pin 22B is one of many ground pins, and your computer should work just fine without it. If I were in your shoes I would do nothing about the missing pin.
KennyPowers
333
369
Exactly what I was thinking, though I know not everyone has the tools and ability to replace a 96 pin connector.
If the missing pin is a redundant ground pin, then it's probably not the cause of your problem @macaphod. You never actually said what the problem with your Cube is though...
Edit: Is this you? If so, that was fast 😂. Probably won't fix anything if a missing ground pin is the only problem with your backplane though:
macaphod
Yes, it's me 😁. The cube is fine, I found about the pin while doing the inspection before testing the computer. By the way, I'm not against repairing vintage computers. For this particular case, it was less costly and took less time than replacing the 96-pin connector.
Thanks for the info about pin 22b. I was trying to find this information, but I couldn't find it.
Thanks to all!
