Hi everybody,
using a Mac IIci with a new Old Net WiFi modem, latest firmware (well, it claims to have shipped with it) and ZTerm 1.0.1 on System 6.0.8. I managed to once set it up according to the docs it came with and connect to the eotd BBS it mentions. I've then changed both modem and ZTerm to use 38400 bauds, saved my config according to docs and went to bed.
The next day I wanted to use the thing again but any keystrokes in ZTerm don't get recognized. Keyboard working fine. Alright, let's set it up from scratch once again and hope it is only a one timer. I'm hitting the flash button for 5 secs as suggested in the docs. It blinks and comes back on. According to the docs, this should set it back to 300 bauds default.
ZTerm was set to 300 baud, XON/XOFF, parity none, data bits 8, stop bits 1 before that. Now all ZTerm gives me are some gibberish chars where the Getting Started guide says it should display plain English.
Another attempt, same result. Now hitting the reset button as suggested by the guide. No dice, another set of gibberish chars being output.
Maybe *flash* didn't overwrite my settings? Switching back to 38400 baud in ZTerm. Low and behold, suddenly keystrokes work again. I can type an AT, but hitting return doesn't send any command to the modem. No response. Yawn.
Everything points into the direction of a mismatch between settings in the modem and Zterm, hence no communication between the two ?
I've tried another 5V power supply and also booting into System 7.1 and running ZTerm on there but no dice either.
Anyone else running into something like that?
What could be the issue?
