older ver. 10-b BlueSCSI Firmware update
slomacuser
82
Hello, just bought ST-LINK V2. Now trying to update older version of BlueSCSI and I need help. So far I have:
- ST-LINK V2
- installed Visual Studio Code for Windows 10
- installed PlatformIO IDE extension
- downloaded BlueSCSI github
- opened folder in VSC
- hook up the pill
- clicked -> upload
and got this error. Tried with holding reset on no luck.
Processing STM32F1 (platform: ststm32; board: genericSTM32F103C8; framework: arduino)
----------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F103C8.html
PLATFORM: ST STM32 (17.0.0) > STM32F103C8 (20k RAM. 64k Flash)
HARDWARE: STM32F103C8T6 72MHz, 20KB RAM, 64KB Flash
DEBUG: Current (blackmagic) External (blackmagic, cmsis-dap, jlink, stlink)
PACKAGES:
- framework-arduinoststm32-maple @ 3.10000.201129 (1.0.0)
- tool-dfuutil @ 1.11.0
- tool-dfuutil-arduino @ 1.11.0
- tool-openocd @ 3.1200.0 (12.0)
- tool-stm32duino @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.90301.200702 (9.3.1)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 32 compatible libraries
Scanning dependencies...
Dependency Graph
|-- SdFat @ 2.2.0+sha.ddbc887
|-- minIni
Building in release mode
Checking size .pio\build\STM32F1\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [====== ] 62.3% (used 12768 bytes from 20480 bytes)
Flash: [======== ] 75.8% (used 49680 bytes from 65536 bytes)
Configuring upload protocol...
AVAILABLE: blackmagic, cmsis-dap, dfu, jlink, serial, stlink
CURRENT: upload_protocol = stlink
Uploading .pio\build\STM32F1\firmware.elf
xPack Open On-Chip Debugger 0.12.0-01004-g9ea7f3d64-dirty (2023-01-30-15:04)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
debug_level: 1
hla_swd
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Error: open failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
============================================================ [FAILED] Took 3.20 seconds ============================================================
Environment Status Duration
STM32F1 FAILED 00:00:03.205
====================================================== 1 failed, 0 succeeded in 00:00:03.205 ======================================================
slomacuser
82
OK, just found Zadig ... something happend now :)
PACKAGES:
Dependency Graph
|-- minIni
debug_level: 1
hla_swd
[stm32f1x.cpu] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08000388 msp: 0x20005000
** Programming Started **
Warn : Adding extra erase range, 0x0800c210 .. 0x0800c3ff
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
=========================================================== [SUCCESS] Took 6.13 seconds ===========================================================
STM32F1 SUCCESS 00:00:06.133
=========================================================== 1 succeeded in 00:00:06.133 ===========================================================
* Terminal will be reused by tasks, press any key to close it.
slomacuser
82
Tried Toolbox, sayin no compatible scsi found ...
the LOG file on sd
BlueSCSI <-> SD - https://github.com/erichelgeson/BlueSCSI
VERSION: 1.0-b
DEBUG:0 SCSI_SELECT:0 SDFAT_FILE_TYPE:3
SdFat version: 2.0.6
SdFat Max FileName Length: 32
Initialized SD Card - lets go!
Imagefile: HD50_512.hda / 2147483648bytes / 2097152KiB / 2048MiB
Imagefile: HD60_512.hda / 2147483648bytes / 2097152KiB / 2048MiB
0:----:----:
1:----:----:
2:----:----:
3:----:----:
4:----:----:
5: 512:----:
6: 512:----:
Finished initialization of SCSI Devices - Entering main loop.
3:----:----:
4:----:----:
5: 512:----:
6: 512:----:
1,301
scsi.blue
The platformio output looks fine, but your log says version 1.0-b - which I don't believe there is such a version (unless you changed it) it should be `VERSION: 1.1-20230709-SNAPSHOT`
Since it looks like you got some odd double output in the log I'd suggest doing a full overwrite format of the SD Card with SD Card Formatter (in the troubleshooting wiki page) to see if that helps.
slomacuser
82
Ok, looks like its updated now but Toolbox apps do not work. Tried updating DB25 also. Same problems no compatible SCSI bus ...
Testing machines Quadra 650 and G3-266.
slomacuser
82
Bluescsi CD changer works but looks for CD files on ID3 even there is CD6 directory on SD card. The Quadra have a real SCSI CD drive installed on id 3.
1,301
scsi.blue
I haven't had a chance to fully test toolbox 1.0 on v1 - It's something I plan to do this weekend and cut a release of v1.
Reactions: slomacuser
1,301
scsi.blue
Just pushed an update to the eric/toolbox branch of v1 - did a very quick test (heading out the door) but SD transfer seemed to work fine.
Please note v1 does not have any of the CD switching code in firmware yet so only the SD transfer utility will work with it.
1,301
scsi.blue
It will depend - if you have or have flashed the USB bootloader, use USB. If not use an STLink. You can tell if you've got a USB bootloader by looking at the log.txt and the version having a -USB at the end.
slomacuser
82
Transfer works now :) thx
Reactions: eric
