Reverse engineering the LC II Logicboard
max1zzz
673
With the (hopefully) final revision of the LC 1 board and the second revision of the LC III both with JLCPCB for manufacture it;s time to turn my attention to the LCII. This was initially going to be the second board LC board I worked on before that pesky LCIII board distracted me...
The boards I am working form where kindly donated to me by cheesestraws from 68kmla for reverse engineering, Many thanks for that!
I haven't taken pictures of most of the process because it's more or less the same process as the previous two boards but here's when I'm at currently:
About 2/3 of the top copper is done, should only be a day or two more till this side is finished :) Then it's on to the bottom side which is always fun due to the huge amount of birdseed that's always on the bottom side.....
I'll post more updates as I work on the design :)
FortyTwo
Bloomington, IN
Wow, looks like you are making great progress! As an LC II owner, I am looking forward to seeing the final result. It's a shame that there is no good, non-destructive method to see the inner layers.
max1zzz
673
I finally managed to get a board assembled enough to test:
I didn't really expect it to work, after all V1.0 boards rarely work out of the box however I flicked the switch and was extremely surprised to hear a clear chime! But I was getting a solid white screen.... The I realised I hadn't installed a VRAM simm, quickly installing one presented me with this:
It works! :)
I can't quite believe it boots with no modifications! (well, at least it boots this far, I still need to solder the rest of the connectors and fully test it so there is plenty of room left for things to not work)
max1zzz
673
Board layout, gerbers and scans are now on GitHub:
As with my other designs these are provided under a non-commercial licence but if you are a repairer and want to offer transplant services (or have any other commercial use in mind) please contact me
