Hi All,
In a tragicomic twist, while trying to fix the unfortunate damage I caused to the logic board of my beloved SE/30 as I inadvertently shorted the external floppy, I decided to run some basic maintenance on the analog board, too.
In particular, I decided to replace the infamous P1 connector, as severely baked at green line pin. Apparently, an easy task.
But when I put everything back together, to my utter dismay the display lasted just a couple of minutes and then, all of a sudden, collapsed to an horizontal line. Vertical sweep gone.
Since according to Larry Pina, it might indeed be an issue with cracked joint on pin 4 of connector P1, I re-flowed it again, maybe it was something not visible. Something has changed, now the screen looks half collapsed: the top half is visible (albeit “squashed”), the bottom half is dark.
Definitely vertical deflection is gone.
Again, according to Larry Pina, suspect is now TDA1170…
Now, before starting the painful process of trial and error for identifying the culprit, I’d like to know if you have any suggestion on what to check first.
Thanks in advance for your support.
