SE/30 won't boot from internal SCSI
CaseyAC
Hi all,
New at posting here but reading the forum has helped me resolve many issues, so hopefully someone will have an idea what could be causing this problem. I'm working on my first SE/30 repair. So far I've recapped the logic board - which restored sound, recapped the analog board - which resolved an issue where the screen would only display a single, bright vertical line, and re-soldered the analog board solder joints - which resolved a screen flickering issue. This SE/30 came with a working original Quantum 40 MB drive, and it booted to that drive just fine up until I tried to replace the ROM. At that point, booting up would get to the "Welcome to Macintosh" screen, then I would get an error that the system file had corrupted. Thinking perhaps the hard drive was on it's way out, I replaced it with a BlueSCSI that I was going to install anyway. With the BlueSCSI installed, I get the flashing "?" icon.
  • The replacement ROM is from Garrett's Workshop - a GW4402B - GW4420B Manual.
  • Taking the new ROM out and putting back in the original makes no difference, I still get the flashing "?".
  • The BlueSCSI log indicates the hard drive image is being found and loaded with no errors.
  • If I boot up using Floppy Emu with "Disk Utilities" loaded, I can see, access, test, update and repair the BlueSCSI, but I still get the flashing "?" when I restart.
  • I tried to install System 7.5.3 onto the BlueSCSI manually from the disk images using Floppy Emu. The install completes but I still get the flashing "?" when I restart.
  • I replaced the BlueSCSI with the original hard drive again and tried to initialize and clean install System 7.1, and I got the error that the system file is corrupt again.
I posted a video to YouTube showing that I can boot up with Disk Utilities and see/access/repair the BlueSCSI drive, but I continue to get the flashing "?":
I took some shots of the logic board showing the SCSI controller area:
and
This would seem to be some sort of hardware issue, right? To me, the logic board and traces look like they're in good shape, so I really have no idea what's going on.
robin-fo
132
62
This is very strange… Did you already try some „known working“ BlueSCSI image? Is the BlueSCSI terminated? You could also try to set the startup disk and then restart.
The original HD is no longer connected?
CaseyAC
Hi - thanks for taking a look! I did try a BlueSCSI pre-made image with the same result. The BlueSCSI is terminated but I did not enable the "BACK_FEED" jumper. I should add this is the BlueSCSI v2 desktop. The original HD is not connected - I've only connected one or the other. I'll try to select a startup disk.
killvore
I'm having a similar issue, so watching this thread with interest! I suspect I may have done a bad job recapping C8-C9-C10 😅
Mine will happily boot from floppy, but does not seem to recognize a known good drive/image (works in my other two SE/30s) so seems to be a SCSI issue.
jmacz
37
26
Where is the bluescsi getting its power from? is it just relying on termination power (ie. via the scsi connection) or do you have it powered using an internal +5V source like a 4pin molex connector?
Just to help rule things out, can you leave the bluescsi connected to the internal scsi connector on the SE/30 but power it using the usb port to an external usb brick (phone charger, etc)? power up the bluescsi first and then turn your se/30 on. See if it boots then. Given you are seeing issues with both the stock and custom ROMs and also with the original working hard disk, I doubt it’s the bluescsi but nonetheless, try this out.
It’s possible the hard disk was on its last legs and is now having issues. But my guess is something went wrong when you swapped the ROM.
Note in my experience, the custom ROM options use newer PCBs that are slightly thinner than the original part Apple used and don’t make good contact with the original ROM socket. This is why multiple vendors provide 3D printed clips to help improve the contact and/or suggest rubber band tricks, etc. I had unexplained IO errors, corruption, crashes, even with these various hacks. I only resolved it by buying a new ROM socket with metal clips that worked perfectly and no longer required any hacks to improve the contact. That could explain the issue with your new custom ROM.
But it’s strange it wouldn’t work even after going back to the original ROM. The original plastic ROM socket clips are brittle, maybe something broke or went wrong there. Or you should probably reflow the solder joints on the ROM socket as perhaps some joints cracked while you were installing the custom ROM.
CaseyAC
Based on your suspicion, I recapped C8-C9-C10 and checked/reseated the rest of them - no affect, unfortunately.
CaseyAC
I was powering only through termination power. Based on your suggestion, I tried powering it with a USB cable and external power brick. Unfortunately, this didn't help.
My SE/30 does have plastic ROM clips, but they look like they're in good condition and I also use 3D-printed external clips as well. Under magnification, it looks like the ROM socket prongs are making good contact with the ROM. The ROM socket solder joints looked like they were in good condition, but I tried reflowing them to see if it would help. Unfortunately, none of this had any affect.
This is really odd because the system worked for a short period after I recapped the logic board and analog board. These issues started after I changed the ROM and HD, but I don't understand how that could have caused this issue... idk, running out of ideas.
InsufficientPostage
I had a similar issue. Tone out the connections between UI12 and the rest of the components. I suspect that you have a broken/corroded trace somewhere. I was having internal and external SCSI issues with my SE/30 where the SCSIProbe was reporting the bus was not terminated, and it turned out that the trace from Pin 20 on UI12 to Data Bus Line 31 had a corroded via underneath UI12, breaking the connection.
You can use the Schematics here on Github (especially the data and address bus line pin matrix at the end) to help you easily tone out all the connections and then just run a bodge wire for the borked trace.
Reactions: CaseyAC
CaseyAC
Great information, thanks a lot! I'll look into it :)
CaseyAC
Just posting an update. I've tested all of the pins from UI12 with no issues - going to keep going through UI8, UJ11, etc. I feel like I have to come across something...
jmacz
37
26
@CaseyAC, I recently picked up a second SE/30 and unlike my first one, this second one seems to be experiencing the same problem you are reporting (although note that I'm using a ZuluSCSI whereas you are using a BlueSCSI).
I was able to run through a bunch of debugging steps and narrow down the problem to some weird inductance/capacitance issue on the SCSI REQ line. From there, @David Cook was kind enough to point me at some SCSI research he did hacking up various active/passive SCSI Terminators to provide a good summary of what makes the black IIfx terminator different. He suggested implementing the IIfx terminator modifications on my SCSI lines and it seems to work. I am consistently able to boot from the ZuluSCSI instead of getting the flashing ?. I still need to digest what this means but it's possible some of the capacitor leakage damaged something adding noise or causing problems on the REQ line.
Not sure if you have the same issue or not, but worth a try. I remembered your post and thought I'd come back here and leave you this note. Here's the thread where I was debugging it at 68KMLA.
Reactions: David Cook
CaseyAC
@jmacz wow, thank you for remembering my post and coming back to comment on it! So, basically, you added a 470 ohm resistor between REQ and TERMPWR? Like on the external SCSI port pins 26 and 48?
jmacz
37
26
I am on the road so can’t check the pin numbers but yes, I placed a 470 ohm resistor across REQ and TERMPOWER, and also two caps, a 2.2uF and a 0.1uF across TERMPOWER and ground. But in my case just the resistor helped. I am still going to debug further and try swapping scsi chips etc. But wouldn’t hurt to try this to see if it helps you.
jmacz
37
26
I got time to swap SCSI chips with one from a IIci (same part number) and determined that the SCSI chip is faulty as the issue followed the chip and now my IIci has the issue instead of my SE/30. The resistor is acting as a pull up to help the chip but the fault lies inside the chip somewhere. Going to leave the faulty chip on my IIci with the resistor modification and see how it does over time.
