Hello!
New here and joined in the hope someone has seen this SE30 odd video issue before!
The machine itself is in very good condition with literally zero signs of battery or cap corrosion. It's been fully recapped also.
The issue is that the right side of the display is literally missing around 8 rows of pixels vertically. This is most noticeable via the lack of top and bottom right side rounded corners where those pixels are missing.
The rest of the machine works perfectly as does its display. Here's the odd part, if you leave the machine running long enough (10-15 mins), those right side missing pixels start flashing back to life! As in, the missing vertical row(s) start to fill with horizontal while lines (flashing), till they're all back again.
Anyone seen this before?
