Sector - Raw HFS Disk Image Creator & Editor
davecom
os9.shop
Hi All,
I released a new little Mac app called Sector for creating and editing HFS disk images on modern macOS (11.5+). This is to make it easier to work with disk images on your modern Mac for emulators like mini vMac and Basilisk II, or virtual disk devices like Blue SCSI, Zulu SCSI, and Floppy Emu.
It can automatically deal with resource forks (wrapping in MacBinary or Binhex) when exporting files from the disk image. It can set type/creator codes. It can choose a blessed folder (although it cannot make a disk image bootable in the first place).
You can learn more about it here:
https://oaksnow.com/sector/
Here are five promo codes for a free copy for the Tinker different community:
H7MFFW4XFP7F
KATKMFWXAWTR
FWL6ENY7E74E
JARTEWELYHH9
F3MPMW73M774
Please make sure to backup any disk images with valuable data before editing them with Sector. Sector comes with no guarantee that a bug won't hurt your data! Any edits you make to disk image with Sector are irreversible. Note it is not compatible with HFS+.
Nitram78
12
Thank you for this new and very useful app.
After a quick test, I can report that it doesn't like file names with accented characters:
The missing letter is an e with acute accent (é)
Trying to open a folder with such name will make Sector unresponsive (endless beachball pointer).
davecom
os9.shop
Thank you. That's a big bug. Thanks for reporting it. Is it possible for you to provide me the exact disk image so I can recreate it?
fred1212
147
I'm dumb where do you apply the code? when I try to get from app store wants to charge me
robin-fo
173
77
Switzerland
I have the same kind of error. Probably bad Mac OS Roman <-> utf8 mapping?
davecom
os9.shop
Yes, it was bad MacRoman -> UTF8 mapping! There is now a 1.0.1 update in the Mac App Store that should fix this issue and a few other bugs. Let me know if you come across any other issues. Thanks!
Reactions: Nitram78
robin-fo
173
77
Switzerland
I've bought Sector from the Mac App store. I't great to finally have a nice GUI for hfsutils and it will certainly help me a lot when working on my projects.
Here are a few suggestions if you don't mind:
- Improve error messages when attempting to open invalid images
- Add context menu when right-clicking on files/folders
- Only show the most relevant file/volume information directly to the user but allow it to be displayed on request (e.g. separate file info window ow view section with disclosure triangle). This makes the UI more user friendly / polished
- Add support for partitions and driver info
- Use the left part of the Split View as list to store favourite images, recently used images etc.. A bit like in Finder or Disk Utility
- We all love Chicago but it looks a bit out of place in a modern app. ;)
- Remove the "Drop disk image here" window. Allow to drag images onto the Application icon instead.
- Read application icons (and custom icons) from the resource fork and show them. You could even try to read the Desktop File and infer the document icons if the associated app is also on the image. Or just have modern, default icons depending on type/creator.
Reactions: Nitram78
davecom
os9.shop
Okay, there's a new 1.0.2 update out on the Mac App Store with a few quality of life improvements based on suggestions from @robin-fo :
- A contextual menu for common actions on files/folders
- Drag to open disk images on the app icon
- A different icon to distinguish apps from documents
Keep the suggestions coming. Thanks!
davecom
os9.shop
Version 1.0.3 is now live on the Mac App Store.
It fixes a folder export bug where files in MacBinary were not getting the .bin extension (and then not recognized as MacBinary on re-import) and adds a tiny UI enhancement with double-click to expand/collapse folders and export individual files.
Reactions: Nitram78
davecom
os9.shop
Version 1.1 of Sector is now live on the Mac App Store.
The biggest new feature is that Sector now will infer the type of a file based on its type/creator code and show that in a column in the main file table. In addition there's now a toolbar button/context menu item to create new folders inside the HFS disk image. Finally, a couple significant bugs are fixed.
