Speed of BlueSCSI 1.0 b
slomacuser
84
I have revision b and wonder if there was speed improvement in revision c or should both had the same speed?
pfuentes69
380
293
Switzerland
Revision C was mostly to facilitate using it on Mac that don't provide termpower (a B can be easily converted to C).
IMHO, the speed increase, if possible, could come by a optimisation in the firmware, but I think the software is stable since long ago.
Reactions: slomacuser
slomacuser
84
Ok, thanks for answer. I have updated the drivers with Disk Drive Setup 1999-2000. Will try to reformat the card with exFAT so will have to use Windows not Mac to write the disc images on..
Reactions: pfuentes69
pfuentes69
380
293
Switzerland
Mac can also format using exFat... no need to go to the dark side for that... ;)
1,542
scsi.blue
If you'd like to "upgrade" your b to c you can follow these instructions - as @pfuentes69 said it's just to allow proper termination in all power scenarios. Also if you bought from a reseller we did the bodge for you after we realized the issue. Hardware revs likely will not change any performance. OS 8 disk drivers (even if you're on an older system) will give you a few % boost. Still trying to get time to finish my utility to do that :)
slomacuser
84
Well, I will leave it as is. Formatting it to exFAT made a 100% increase in speed! 🤯
Testing with Norton System info the drive made a score of 55 (Just a little above Mac SE and below LC II), updating drivers made it a little above 60. Formatting the card made it 125 just above Quadra 700, 950, PowerBook 5300 and Duo 2300 which got 113 ...
slomacuser
84
One more question. I can not use any system software above 7.5? System 7.1 and 7.5 work fine. System 7.6 or 8 do not. They lock just before loading desktop and alert box about wrong time clock.. any idea?
pfuentes69
380
293
Switzerland
I had success with 7.6.1, but not when trying 8.x. I think later Eric made a better image to run 8, but didn’t try yet.
What machine are you using? I think 7.6.1 needs a 32bit clean rom, but not 100% sure
pfuentes69
380
293
Switzerland
slomacuser
84
1,542
scsi.blue
You have an even earlier version. To be stable on faster machines you'll need to update.
