Synchr030/S 256MB SDRAM Accelerator for the SE/30
YMK
407
342
Synchr030/S is a 256MB SDRAM accelerator PDS card for the Macintosh SE/30. It combines a custom memory controller with 256MB of SDRAM to double the SE/30's memory capacity and throughput. There's no longer a need to deal with broken SIMM slot tabs, dodgy contacts or aging SIMMs. Synchr030/S provides fastest possible 2-cycle reads and writes to the 68030 CPU, making it the performance equivalent of a 256MB L2 cache that never misses.
To enable 2-cycle reads, installation of the included /ECS Tap PCB is required. This small board fits over the CPU pins on the back of the logic board and routes the CPU's /ECS signal to the PDS card. This signal is not present in the SE/30's PDS connector:
A System 6/7 extension enables fast 2-cycle access to SDRAM and expansion to 256MB under System 7 with a IIsi-derived ROM, such as the Rominator II. The extension also performs ROM shadowing, which relocates ROM-resident Toolbox routines to SDRAM, where they can execute faster. Without the extension, the card operates as 128MB of DRAM with the stock 4-cycle access time.
The controller operates at 63MHz, providing a 32-bit data path to memory at a maximum throughput of 31.33MB/s. Unlike the stock DRAM controller, Synchr030/S does not stall for refresh cycles, so consistent access times are guaranteed. All signals through the card are unbuffered, routed directly to the PDS passthrough connector. The two large capacitors on the board are polymer and will not leak.
Connectix Maxima is supported under System 7, which enables large, disk-backed RAM disks. SDRAM-based RAM disks typically yield 4.5MB/s with the stock CPU, faster than any SCSI device.
/STERM and /DSACK signaling options are selectable via jumper for compatibility with CPU accelerators. Compatibility is confirmed with @zigzagjoe's Interware Booster 50-SE30F clone (with /DSACK) and @Bolle's PowerCache P33 (with /STERM). Both of these accelerators benefit significantly when paired with Synchr030/S.
On the rear of the PCB, three LEDs indicate various conditions. These are visible through the SE/30's frame, and MacEffects clear case:
  • "ACCEL" LED (emerald): Indicates fast 2-cycle SDRAM access, after the extension is loaded.
  • "/ECS" LED (white): Indicates activity on the stock CPU's /ECS signal. Will be off when a CPU accelerator card is in use, even if connected to the logic board.
  • "FPU" LED (yellow): Indicates floating point unit access. This indicator is mirrored at the "FPU LED" through holes at the upper right corner of the PCB. An external LED header may be soldered here if desired. No resistor is needed.
MacBench 3.0 Results:
Performance summary:
MacBench 3.0 CPU score: +24%
Apple Personal Diagnostics 1.1.1 memory bandwidth: +70%
Specifications:
Power consumption: 0.43A @ 5V (2.15W) typical
Capacity: 256MB
Bandwidth: 31.33MB/s R/W
Clock speed: 62.66MHz
Slot space: C, D
Connections: SE/30 PDS male and female, expansion port, FPU LED
Weight: 123g
PCB construction: Eight layer, ENIG
Note:
  • CPU accelerators may be sensitive to placement in the PDS chain.
  • BMOW or other IIsi-derived ROM is required to enable 256MB under System 7.
  • Basic soldering skills required for installation.
Special thanks for compatibility testing, accelerator insight and feedback:
@JDW @Bolle @zigzagjoe @MacEffects
1,952
Folks, I've done extensive testing with this fabulous 256MB card, and have been pondering a video about it, but I've just been so busy with other video work (and my day job — man, I need to retire!) that I've not gotten around to it yet. And I do apologize for that because the blood sweat and tears that went into making this amazing card is simply incredible. YMK is to be highly praised for doing such innovative work!
You can have fun pestering the vintage Mac community with the question: "What's the maximum RAM I can install in an SE/30?" And when they all reply 128MB, you can fire back with: "Nope!" :cool:
Yes, yes... I know... You may thinking that even 32MB of RAM "is enough" in an SE/30, but consider the possibilities with a massive RAM DISK.
If you don't care about acceleration (which means the card RAM will run only as fast as stock RAM SIMMs would), you don't need to solder on the little /ECS Tap PCB to your motherboard. But of course, you would then lose one big advantage to having that card. Acceleration is pretty neat.
My notes have the following points of interest:
  1. Up to 256MB of card RAM can be used under System 7, but only up to 128MB under System 6.
  2. Extension is not required for the card to function. Those two files unlock acceleration, including the copying of ROM into fast SDRAM for improved toolbox routine performance.
  3. All motherboard RAM must be REMOVED before using the card. (But this is a BENEFIT, actually. Many RAM sockets have broken tabs these days.)
  4. Card does NOT disable RAM checks at cold boot. So if you don't install a custom ROM SIMM that kills cold boot RAM checks, you will spend an eternity waiting every time you flip on power. A custom ROM SIMM does not mean a stock IIsi, IIfx, or IIci ROM! Those ROM SIMMs are compatible, but they do not kill RAM checking at cold boot! Take note!
  5. The ROM-inator II (with IIsi-derived ROM flashed), or similar custom ROM SIMMs from CayMac Vintage, Kero's Mac Mods, GGLabs, SiliconInsider, Garrett's Workshop is recommended to disable RAM checking at cold boot, and to enable extra RAM under System 7, and for the Extension to copy ROM contents to fast 2-cycle SDRAM.
  6. Connector at the top is PDS “pass-thru” and is not for cache cards like the Turbo040. But accelerators like the DiiMO, or Ethernet cards like MacCon will work fine because they are true PDS cards, not cache cards.
  7. The small "/ECS Tap" PCB is optional. It won't cause problems with any PDS cards you have installed in your SE/30 or even if you have no PDS cards installed at all. When that small PCB is installed on your motherboard and its jumper wire attached to the RAM Card, and when the Extension is also installed, it will boost memory performance from 3 cycle Reads to 2 cycle. The board is easy to install. It is to be soldered only at 2 points to the bottom side of the SE/30 logic board. A jumper wire leading from the small PCB to the PDS card must slide onto the /ECS pin that is on the RAM Card.
For many, the biggest reason to buy and install this RAM Card isn't the acceleration it offers or even the massive 256MB of RAM. It's broken RAM SIMM slots! Swapping those out is a real pain, and paying somebody else to do it is costly. Installing YMK's RAM card means you don't need to worry about those slots ever again, and you get a massive amount of RAM and in some cases RAM acceleration too! Plus your helping a small developer to continue to innovate and produce some insanely great stuff for the community. It's worth a look for any SE/30 owner!
1,952
This is amazing! I would definitely like to try one out in one of my machines sometime.
It really is an incredible design. If you read through the opening post again, you will see it is an 8-layer PCB! It was then made in a very lovely matte black, with gold ENIG plating. The amount of time invested in engineering that card by a single person must have been substantial.
Reactions: YMK and JTRetro
JTRetro
44
8-layer PCB-that is very impressive! Definitely a lot of work went into this. I'm really happy to see all of the products that are being made to keep our classic Macs alive....and still very much functional!
I do have one question about this though- does it have just one pass-through slot or two? I'm currently using one of Bolle's adapters, and I have a Daystar powercache in one slot and an Interware Grand Vimage 24-16s in the other.
Reactions: YMK
YMK
407
342
It has one PDS pass-through slot.
1,952
I'm currently using one of Bolle's adapters, and I have a Daystar powercache in one slot...
I too have a Daystar PowerCache accelerator in my SE/30, but mine is the CPU-socketed type which requires a socketed 68030 CPU type motherboard, but NO ADAPTER. That type of PowerCache looks like this:
(Photos taken back in 2013, so ignore the motherboard caps and PRAM battery. MB has been reworked since then.)
I feel compelled to mention this because many people use the word "PowerCache" freely, as if there is one type. But as you can see, there are indeed more than one type which can work in the SE/30, and they don't all install the same way, nor are they the same shape.
Accelerator cards that typically install in a cache slot, such as the cache slot on a Macintosh IIci, require a special adapter, such as the one from Bolle or the TS Adapter from Artmix Japan like I have:
⚠️ Inserting a "cache slot" style accelerator directly into the PDS slot of an SE/30 will fry the accelerator card and possible harm the motherboard.
⚠️ Inserting a "cache slot" style accelerator directly into the upper "pass-thru" PDS slot on the Synchr030/S RAM card will fry the accelerator card and possible harm the Synchr030 and motherboard.
Reactions: YMK
YMK
407
342
Some background on the card's development... The current "Rev A" is the sixth revision, after revs 1-5. I designed it originally for the LCIII PDS slot along with an SE/30->LCIII riser adapter because I hadn't decided on which machine(s) to target. Beyond the pinout differences, there were too many compromises in supporting both 16MHz and 25MHz Macs, so I focused on the SE/30. This is Rev 2, for the LCIII slot:
MeTheMac
72
16
Mars
Hi, I just purchased a 30Video HC LCD Kit, Syncro30/S, and a Slot Booster 2.0. Have you ever tried a similar, three-card setup?
Was thinking that if the Slot Booster 2.0 went first, it would raise the Syncro30/S up just enough to be able to plug the 30Video card in and fit with the absence of a CRT (and a color LCD in its place). Also wondering if you had any idea if this would work electrically? I have a new PSU unit, of course.
Tysm for all the help, and great work!
(originally from my Reddit comment on r/VintageApple)
1,952
BTW, if anyone would like to have the startup screen I made for my video (shown on the SE/30's CRT), you can download Photoshop, PICT and "StartupScreen" formats in the attached Stuffit 1.5 archive.
  • Sync030-StartupScreen.sit
1,952
@MeTheMac
While we await word back from @YMK or @zigzagjoe , I would just like to let others reading our dialog know that the "30Video HS" info is found here:
I also see a similar question asked on that forum here too.
I've not contacted YMK since the release of my video because I suspect he may be swamped with questions right now. But if there are no replies from him or ZigZagJoe 24 hours from now, I will send them both PMs to ensure your question is answered.
YMK
407
342
I have not tried that three card setup. You might be the first.
MeTheMac
72
16
Mars
Interesting! We shall see then! I'll be sure to report back here to see if it does work! Do we know of the Syncro030/S working with the 30Video card alone?
1,952
The reason I tagged @zigzagjoe is (1) he created the 30Video clone and (2) he has a Synchr030/S. Of course, there could be other people who have both cards, but I'm not sure who they are. People with both cards are of course the people we need to hear from.
1,952
It appears to work with the grayscale card. I don't know if it's the same as your card:
And of course, knowing if the 30Video series cards need a 180Ω pull-up resistor mod like the Booster 2.0 does, in order to use the card in the top slot of Synchr030, would be good info too.
MeTheMac
72
16
Mars
I was planning on using the Booster 2.0 in the first slot and connecting the Synchro030/S onto that. Do I need to add a resistor for that to work or is it only when the Accelerator is attached onto the Synchr030/S?
I believe the Grayscale card is different (but don't quote me on this!). Even so, I have a good feeling that the 30Video will work!!
Also, do I need to provide support for the card connected to the Syncro030/S so that it doesn't sag or anything?
This forum is awesome, btw!
YMK
407
342
Only when Synchr030/S is on the bottom.
If the card is much larger than the Booster, it's a good idea.
