Trouble with Sound Driver on LC/LCII
Scott
52
26
I have some LC and LCII boards that were recapped over a decade ago by someone who no longer does re-caps that share a similar problem.
On the surface, these computers work fine. They run well, they chime upon startup, they do everything you'd expect them to.
The problem is that they have an issue with old sound driver playback. Not sound manager (the snd resource), but the old songs that were common in some games. These are the ones that won't play on a Power Mac.
Specifically, they have issues with Super Solvers Midnight Rescue and Super Solvers OutNumbered, where the sound is very low, seems to be only one channel, and is not audible.
These two games actually are of note because they play a different soundtrack depending on whether the computer is a mono or stereo output. If I load either on, say, my SE/30, you'll get Midnight Rescue playing "The Sorcerer's Apprentice" in stereo beginning on a concert A. It will be more simple on something like an LC, SE, or Plus and will start on a concert D.
Every LC and LC II *should* play the mono version regardless of whether it runs System 6 or System 7. (An LC III always would play the stereo version). It seems these LCs try to play the stereo version and fail miserably.
I'm wondering where the problem here lies, and I have it down to a few possibilities (all of which could be wrong, hence why I want to run it out here):
1. Some capacitor that governs the sound chip was replaced with an improper capacitor. (Back when these boards were re-capped, some people would use different caps to try to optimize the computer long-term, which didn't always work).
2. There's some kind of goop that wasn't cleaned up that landed near where something important for the sound chip is.
3. There's a software issue (although all of my Macs share a common deployment of System 6.0.8 and the other LCs with this work just fine).
4. Something else??
VeryVon
What happens if you try the 1/8 audio jack with an external speaker? Same issue? I believe both the LC & LCII have 8-bit mono sound output.
Scott
52
26
I'm going to test a few of these out again this week and will put some wired headphones on them to see what happens.
VeryVon
I ran Super Solvers Midnight Rescue on my LCII. Here's what it sounds like.
VeryVon
Ok here's the floppy version I believe. Volume is set to 5/7. It sounds a bit quieter than the CD version at the same level.
  • PXL_20260813_151839118.TS~2.mp4
Scott
52
26
OK, what hardware do you have it on? I can tell it's System 7.5 from the menu bar.
I have never tested Midnight Rescue under System 7.5.x, but I know it sounds different under 6.0.x, 7.0.x, and 7.1.x on an LC or LC II.
The audio in your clip is consistent with what I'd expect out of any Mac II, SE/30, LCIII, any LC 500 or 040 based Mac in which Sorcerer's Apprentice starts on a concert A and is quieter.
On a standard LC or LC II or any 68000-based compact (SE, Plus, Classic), it should be louder and start on a concert D. I believe this has something to do with the sound being mono on these models.
If possible, test on an LC/LCII with System 6. All of my lab machines in question run 6.0.7 and none are LCIIIs.
VeryVon
Sure, here's what it sounds like on the LCII in System 6.0.8, on internal and external speaker. I can hear what you're talking about now!
For the "internal" version I cranked up the volume to 7.
  • internal.mp4
  • external.mp4
Scott
52
26
Yes, this is the issue. If you have access to another LC or to a Plus, SE, or Classic, note the difference. This is not what that music is supposed to sound like under System 6. I can verify this because some of my LC/LCII don't have this issue plus I remember long before capacitor goop how these things sounded at my school and at home.
VeryVon
Agree. On the SE/30 it sounds good and the same on system 6 & 7.
You said you have some LC/LCII machines where it plays correctly under system 6?
Scott
52
26
Here we go. I'm actually running 7.1 on this LC (this is not one of my lab LCs) but it does the same playback as System 6 would do here. This is what an LC or LCII should sound like (also a Classic, SE, or Plus).
