Troubleshooting Macintosh Portable after loading 12V line-- self inflicted.
campbellashe
59
30
Asheville, NC
Okay. I was getting excited and tried to internally power and LCD replacement off the J15 connector -- using 4 12 volt lines and 4 GND lines to power a barrel connector and a 12 volt LCD -- yep. Shouldn't have done this. The LCD did power on; but now my computer will not boot. NO smoke; no pop, no obvious overheating.
What is working:
  • F1 good
  • +12V converter working
  • Main +5V present
  • +5V reaches RAM
  • No hard short on +5V
  • No hard short on +12V
Where I’m currently stuck​
The machine has valid power rails, but:
  • SYS_RST* never releases
  • RESET stays low
  • HALT stays low
The CPU never starts executing.
Looking at the schematic, R13 (1 kΩ) connects SYS_RST* to the CPU GLU NORM_RST* signal. My next thought was to lift one side of R13 to determine whether the PMGR side or the GLU side is asserting reset.
Questions​
  1. Has anyone seen this failure after overloading the J15 +12V rail?
  2. Is lifting R13 the best next diagnostic step?
  3. Is there a known failure in the PMGR, hybrid, or CPU GLU that will permanently hold SYS_RST* low while +5V and +12V remain normal?
  4. Is there another signal I should measure before lifting R13?
Thanks for any guidance.
David Cook
277
339
Yes. I believe there is an analog voltage provided to the PMGR that represents some fraction of the battery voltage. This allows the PMGR to know when the Portable is plugged into an outlet and to be able to measure battery discharge levels. I believe this also allows the PMGR to soft shutdown when levels get too low. My understanding is that if this value gets too high it can damage the PMGR (such that it won't turn on the Portable) or too low such that it thinks the battery is too discharged (and also won't turn on the Portable).
Perhaps pin 52?
Reactions: campbellashe
David Cook
277
339
On other forums @techknight has said:
"What I need you to do now, is check the voltage at the Hybrid, on the pin literally behind the NMI button. it goes into that Op Amp sitting below. It should hover around 2.2 to 2.5VDC. if it falls to 0, or latches at 5V, the system will NOT stay on.
If that looks good, I then need you to check for roughly the same voltage at the PMU on Pin 52. The signal gets filtered by a low-pass sitting at R151 and C107. if anything is wrong there youll get issues."
daanvdl
17
14
Netherlands
Before lifting R13, I would first check the reset input of the Power Manager MCU.
Last week I repaired a Macintosh Portable with somewhat similar symptoms. In my case, SYS_POWER never toggled, although AKD activity was reaching the Power Manager.
For reference, I compared the Hybrid/Power Manager voltages with the known-good measurements in Androda’s spreadsheet
https://docs.google.com/spreadsheets/d/1UuimsU50-zfGkfePpQFFvMdw2yRpz3iFfBIIjOgnKow/edit?usp=sharing
Before lifting R13, I would also check PMGR_RESET* directly at pin 18 of the Power Manager MCU while triggering AKD.
On the machine I repaired, PMGR_RESET* was normally high, but during the reset pulse it did not fall low enough to be recognised as a valid TTL-low level.
According to the schematic, the same signal path both holds MCU pin 18 high during normal operation and pulls it low during reset:
PMGRST* from the GLU PIn 62 → S1 pins 4–5 → PMGR_RESET* → MCU pin 18.
The fourth switch section in S1 had developed some contact resistance. The high idle level still looked normal because the MCU reset input draws very little current, but when the GLU tried to pull the line low, the resistance prevented pin 18 from reaching a sufficiently LOW.
Bridging the S1 contact between pins 4 and 5 restored a clean reset level, and the machine booted.
If you can measure clock activity on signals generated by the Power Manager MCU, that is also a useful sign. It suggests that the MCU is receiving power, its oscillator is running, and at least some of its internal logic and output stages are functioning. It does not prove that the MCU is fully operational or executing the correct firmware sequence, but it makes a completely dead MCU less likely.
It may not be the same fault, especially since your failure followed a 12 V overload, but it is a quick and non-invasive check.
Reactions: David Cook
campbellashe
59
30
Asheville, NC
Recap: After correcting the J15 power tap wiring, the Portable stopped booting. SYS_RST*/PMGR_RESET* stuck at 0V, F1 good, PMGR clock running.
Traced PMGR_RESET* (J21 pin 46) to U15H pin 18 — the PMGR's hardware RESET input — confirmed via two independent schematic sources. The physical RESET button doesn't feed this pin directly; it goes to a firmware-read GPIO instead.
Pin 18 is not stuck low — reads 5.1V, matching a direct chip measurement. But even released, no chime, no boot, and SYS_RST* still reads 0V.
A/D battery-sense line (pin 52) reads 2.7V, matching the hybrid's output — no active overvoltage right now.
Voltage-scaling test shows the hybrid behaving non-linearly within its own normal operating range (5.4-7.5V):
InputA/D output
6.5V2.7V
6.0V1.7V
5.6V0.4V
Not proportional — points to genuine hybrid degradation (resistor drift), not a bad test voltage.
Chip pin 12 = SYS RESET (confirmed), held cleanly low — not floating, consistent with the PMGR actively running firmware and choosing not to release the system, not a dead chip??
Logic analyzer testing (Rigol DS1104Z Plus + RPL1116), watching pins 12/18/16 plus the GLU source (61/62) simultaneously during AKD triggers: AKD fires correctly (clean pulse confirmed at C116), but nothing downstream reacts — rules out contact resistance in S1 (suggested earlier — appreciated @daanvdl , but the GLU never even attempts a pulse).
Current theory:
a) PMGR is alive, firmware is gatekeeping??? — most likely on the A/D reading, given confirmed hybrid degradation.
b) PMGR is broken -- I just have to accept it?
Next:
1) Thought about isolating R151, injecting a clean ~2.4V directly into the PMGR's A/D input via a breadboard divider, bypassing the hybrid, to test this directly.
2) Do I just replace the Hybrid
3) Replace the PMGR when my donor Powerbook 100 comes??
Froggy814
147
42
Squaw Valley, CA
I would try everything in my power not to have to replace the PMGR. But of course, it is always a plausibility it is something else nobody knows of.
daanvdl
17
14
Netherlands
InputA/D output
6.5V2.7V
6.0V1.7V
5.6V0.4V
Current theory:
Next:
Let me know if there’s anything else I should measure or scope to help narrow this down for you.
campbellashe
59
30
Asheville, NC
Okay here is a new problem. No 12 Volt line.....
Current measurements with bench supply at 6.5V:
  • ALWAYS ON +5V (hybrid pins 11/18): 5.2V ✓
  • Main (5/0) rail (J11 VCC): 5.2V ✓
  • +12V rail (J15 pin 9): ~0V ✗
  • Q14 gate (IRF9230, P-channel): 6.5V = Vgs 0V = OFF
  • Q14 source: 6.5V
  • VR1 LT1070 pin 5 (VIN): ~0V
The hybrid is regulating ALWAYS ON and enabling the main rail correctly. But Q14 gate is sitting at supply voltage (not being pulled low by the hybrid), so Q14 is off, VR1 has no input power, and the boost converter never runs.
Adding the power brick alongside the bench supply makes no difference — Q14 gate rises with the supply but stays at Vgs = 0.
Questions:
  1. Does the hybrid require a signal from the M50753 PRMG before it enables the +12V generation circuit? Is +12V gated on PRMG being alive?
  2. Is there a known sequence where +12V only comes up after a successful power-on, rather than at standby?
  3. The PRMG (U19H) also shows no response to keypress with both rails present — is this consistent with PRMG damage from the original 12V event?
  4. Is this a new problem related to my new Hybrid board?
campbellashe
59
30
Asheville, NC
I had to source from a non working Powerbook 100 that I got online. I felt guilty, but I'll still work to get the Powerbook working again if I can. Need to really see if the community can help recreate the PMGR chip in some fashion.....
  • Sad
Reactions: ClassicHasClass
