This insanity started just about 5 years ago:
68kmla.org
Best explanation: TwinSlot Riser for TAM & version for 6360.
Looking at having a USB connector and a 12v in jack for powering the two PCI Slots with Buck converters on board, that I might be able to handle.
Developing a repro 10/100 NIC in the form factor of the TAM's ComSlot Riser and powering it from same would be oh so cool, but beyond my ken.
So we've got squat for power in the TAM, might feeding 12V into the backplane power the three expansion cards?
Table 4-11 Pin assignments for the PCI-bus communications slot connector
Odd-numbered pins Function Even-numbered pins Function
1 /DCD ____________2 /DTR
3 /CTS_____________4 /RTS
5 RxD _____________6 TxD
7 IN_SENSE _______8 SCC_ENAB
9 INT_MIC _______10 MIC_SENSE
11 MIC_RET______12 EXT_AUD_L
13 Reserved _____14 EXT_AUD_RET
15 GND__________ 16 +12V
17 -5V___________ 18 +12V
19 SYS_WAKEUP _20 Trickle +5
21 GND __________22 GND
23 A1 ____________24 A0
25 A3 ____________26 A2
27 +3.3V _________28 +3.3V
29 A5 ____________30 A4
31 A7 ____________32 A6
33 +5V ___________34 +5V
35 A8 ____________36 C/BE(0)~
37 A10___________ 38 A9
39 GND __________40 GND
41 A12 ___________42 A11
43 A14 ___________44 A13
45 C/BE(1)~ ______46 A15
47 GND __________48 Gnd
49 SERR~ ________50 PAR
51 PERR~ ________52 SBO~
53 LOCK~ ________54 SDONE
55 +3.3V _________56 +3.3V
57 DEVSEL~______58 STOP~
59 IRDY~ ________60 TRDY~
61 +5V___________62 +5V
63 C/BE(2)~ ______64 FRAME~
65 A17 ___________66 A16
67 GND __________68 GND
69 A19 ___________70 A18
71 A21 ___________72 A20
73 A23___________ 74 A22
75 GND __________76 GND
77 C/BE(3)~ ______78 IDSEL
79 A25 ___________80 A24
81 A27 ___________82 A26
83 +3.3V _________84 +3.3V
85 A29 ___________86 A28
87 A31 ___________88 A30
89 +5V ___________90 +5V
91 REQ~__________92 GNT~
93 +5V____________94 +5V
95 INT~ __________96 Reserved
97 Reserved _____98 RST~
99 GND _________100 Reserved‘
101 CLK ________ 102 Reserved
103 GND ________104 Reserved
105 Reserved ___106 Reserved
107 Reserved ___108 Reserved
109 CommGnd __110 RefGnd
111 AudToSlot __112 AudFromSlot
to be continued . . .
Twin PCI Riser Project for TAM, 6360, 5x00 Single Slot PowerMacs.
My 63060 and its 5400/5500 low drawer brethren are fairly low hanging fruit as far as this project goes, so I'm taking on the TAM challenge first. Cutting that riser down and removing the rearward offset is not biggie, but fitting a second, low profile PCI Card into available CS2 cubic is a...
![68kmla.org](https://68kmla.org/bb/data/assets/logo/68kmla-512.png)
