Store
JeffC
SE/30 with abnormal screen
The SE/30 is the most popular compact Mac, in the US a working SE/30 logic board will probably cost at least $200 USD. You are better...
Jun 25, 2025
nekogahora280
It seems like replacing all the capacitors might be the best approach. However, it also feels like it could be faster to look for a...
Jun 25, 2025
Floppy drive Sony MP-F51W-23 upper head doesn't touch the disk
Physical size of SMD resistors varies by power handling. Even a 1/32W resistor should safely act as a pull-up in this case, I would...
Jun 25, 2025
D
Dave928
MacEffects Appreciation Post
we've come a long way from hand-drawn tracings and a crock pot full of acid etch.
Jun 25, 2025
This is great test. How many millimeters from the lens front to the film?
Jun 25, 2025
tom_B
A few PCB manufactures do full color PCBs now(Both JLC and PCBWay do, probably others too) As of september year they had different...
Jun 25, 2025
S
Sjuul010
Can se/30 flyback be replaced by a 157-026C flyback?
Yes, I figured this one lacks the bleeding resistor. But like you said, better something than nothing.
Jun 25, 2025
AvadonDragon
It SHOULD work just fine. The older part could be lacking the bleeder resistor. I don't recall which models included it. Everyone...
Jun 25, 2025
XKSTEVE
A2DVI altchr switch
Apple I/II/III
Has anyone got the ALTCHR feature to work? I have Three cards and multiple //e computers and none, in any combo, allow this feature to...
Jun 25, 2025
B
billbucks
For the resistors, would you recommend using SMD components and normal ones ? If I use SMD, I wonder if it'll work soldering it both on...
Jun 25, 2025
