Store
ACGuy
Macintosh SE works but has no sound
Hi Kai, I have 4 MB installed, and my logic board is the one with the jumpers. I haven't touched them, but I can try reseating the RAM...
Aug 6, 2025
Checkerboard like that indicates that the CPU is running, it's not being held in RESET and the ROM is working - you're experiencing a...
Aug 6, 2025
ACGuy
Compact Macs
Hello, this is my first post here after years of lurking around. I ended up registering because I’d need some help with my Macintosh SE...
Aug 6, 2025
Markintosh
Yes, that was me who said I only needed one. If you still have one I’ll take it, but if others are interested-they can have the one you...
Aug 6, 2025
I
indibil
G4 Cube revival help?
As a curiosity, if you try to turn on the Cube with the top plate unscrewed, where the button is, since it's not grounded to the...
Aug 6, 2025
kallisti5
Macintosh Classic Floppy Drives - auto-inject.
Ha! I think I actually just fixed it. Did a little more bending of the heads with the drive out of the Classic and finally got the...
Aug 6, 2025
I
indibil
Project Satanicube (or, Xodium's G4 Cube Build)
Very good contribution. I also had a processor height issue because it was too low, and I solved it by sandwiching a thin 0.5mm copper...
Aug 6, 2025
I
indibil
G4 Cube VRM
Hi, I initially wanted to do it with a preheater and a hot air soldering iron, but I didn't want to overheat the components I'd be...
Aug 6, 2025
V
vtgearhead
Earlier this week I did the same thing to one of my SuperDrive mechanisms. After a bit of shameful language, I realized the little coil...
Aug 6, 2025
