Store
N
nottomhanks
Mystic PPC WITH Apple IIe card
Thanks!! It was fun putting that together. You can purchase the 120 pin PDS socket that simply passes the pins through like an...
Aug 17, 2025
B
BobDaAggie
Way cool video! Thanks for sharing. How did you make the pds riser?
Aug 17, 2025
N
nottomhanks
Yessir! Here’s the video:
Aug 17, 2025
B
BobDaAggie
nottomhanks did you ever make that video about the ppc and Apple IIe card? Also where dit you get the odd riser?
Aug 17, 2025
jdmcs
Swap Meet Near Dulles, VA on August 24: Retro Bits and Bytes Swap Meet
Events & Meet-ups
On August 24, 2025, the Retro Bits and Bytes Indoors Swap Meet will be held at the Dulles South Recreation and Community Center from...
Aug 17, 2025
PowerMac 7100 and Linux (and NetBSD)
Click the "Toggle BB code" button. Then edit the BB code. Use "Preview" to verify BB code changes. I usually edit posts as "BB code"...
Aug 17, 2025
Elosha
Disk Jockey v4 for macOS is out
@OneGeekArmy I will, but probably easiest would be to a) Rather detect the ATARI OEM signature "Loader". Because PCs would use OEM...
Aug 16, 2025
jdmcs
Documentation for DB15 to VGA adapters
I just found switch settings for the Belkin F3H1381... both versions. Hopefully this helps someone with this adapter, especially because...
Aug 16, 2025
