Store
S
StudioLou
Easy way to transfer files to and from iMac G3?
Hi Byte Knight. I have the same problem – old files on a G3 – and ran a quick export test using your Server. It worked! I wanted to get...
Aug 26, 2025
SE/30 Reloaded Board - First Test
Nope - those are the 65C22S's - not the 65C22N's which have an open drain output, designed to replace old NMOS parts like the SE/30...
Aug 26, 2025
chuck.dubuque
Analog board - display horizontal alignment
Hot glue is probably the way to go if you want to fix them. It took a lot of pressure for mine to move so I left them, but if yours are...
Aug 26, 2025
K
kaltree
Thanks for the tip - I hadn't adjusted these rings before, but that was definitely the fix. Reading the linked document, I found a...
Aug 26, 2025
Steve Rieck
I will get replacement VIAs next. I'm hoping these are correct...
Aug 26, 2025
chuck.dubuque
I've done it myself twice---once for ZZJ's grayscale board, and once when I transplanted a green CRT into my SE/30. You just really want...
Aug 26, 2025
K
kaltree
Thanks for the link! I'll save that one for sure. Envious of the brand new flyback transformer in that document. Since I didn't have...
Aug 26, 2025
Well, i mean both harvested from an original board AND from sources like UTSource - i'd still not rule out either VIA even if the chips...
Aug 26, 2025
B
BobDaAggie
PDS Connection Hardware
Well that part did not have all 96 pins populated. I did find this on Digikey and it seems to be close. Does anyone have any experience...
Aug 26, 2025
