G4 Digital Audio and 20" (A1038) Cinema Display -- goes blank on bootup
So when you fully boot into safe mode, what is the resolution? Do you have any other boot drives or optical media to boot from? Sounds...
Sep 7, 2025
F
flainn
I looked at the available resolutions (using my CRT monitor) and none of them seem to be supported by this display, which may be the...
Sep 7, 2025
Could it be trying to go to a resolution that is not supported? What resolution is your CRT? Try connecting your CRT, fully boot, set...
Sep 7, 2025
K
KenDesigns
Running a Neural Network on a Mac 128K
Compact Macs
Hello all, my first post here. I have been working on a small project where I tried getting a neural network to run (performantly) on...
Sep 7, 2025
F
flainn
Hi, unfortunately I don't -- the only other card I have has a DFP connector and not an ADC connector. I do have a G5 on its way to me...
Sep 7, 2025
_nec6678
Do you have another graphics card compatible with the G4 to try the Cinema Display with?
Sep 7, 2025
F
flainn
PowerMac G4, iMac G4 & eMac
Hi folks, I've got a G4 Digital Audio which works great with a CRT monitor. Yesterday I picked up an A1038 20" Cinema Display (the one...
Sep 7, 2025
_nec6678
The BlueSCSI Project: Replacing My Dead Quantum ProDrive
Finally! I got a BlueSCSI from JCM, preassembled. I believe it has wifi functionality, but I haven't tried that out yet. I was initially...
Sep 7, 2025
T
ThePhage
Yes, so far I’ve found good frame rate conversion results with the re-time Speed Warp (better) setting in Resolve. I denoise before...
Sep 7, 2025
F
frontein1
Close. There are distinct steps to test the RAM and size the RAM. All versions of this ROM bypass testing RAM (onboard & SIMM) to...
Sep 7, 2025
fogWraith
Error 403 – unable to access Macintosh Garden anymore
I wouldn't know, I don't use it nor do I have any device using it outside of the network to test it properly - though I would suspect...
Sep 7, 2025
R
rdesros
Don't forget the 24p upscaling. It's really good. It really make a difference when i playback a video with Infuse on Apple TV. My TV...
Sep 7, 2025
