TheElk
I tested the change due to scan a white prelude tape. And like posted in #657 you can may be see the change
Oct 10, 2025
The great LCD in a Color Classic thread. Well, I wish...
So that's the gotcha. You must choose one of two Analog Board types for the LCD kit. I recently converted my 68.4V standard VGA mod to...
Oct 10, 2025
ESM-NL
Yes, that's correct. But watch out: there are two versions replacement types ABs: one type that only works for the stock...
Oct 10, 2025
robin-fo
Macintosh Quadra 950 green screen output
This is normal and happens with many Macs. Try different adapter settings.
Oct 10, 2025
TheElk
Are you sure we all have the same V6.8 version like you ? Could you test with a white prelude tape ?
Oct 10, 2025
T
toples50
Reviving a sad looking Quadra 840av
My Q840av motherboard
Oct 10, 2025
I'm still not seeing any exposure errors with 6.8.
Oct 10, 2025
It is the film not, the scanner or firmware, that is getting dark, as the scanner exposure is not changing. The exposure is not changing...
Oct 10, 2025
Destroyer1976
Macintosh Quadra & Centris
I don't know if anyone has a solution to my problem but here it goes. I have a mac quadra 950 which I'm running on VGA output. I can...
Oct 10, 2025
jackmonte1987
Here is a short video where you can quickly see the transition. I power cycled the unit and retried the scan, and it did the same around...
Oct 10, 2025
