unlawfulsoup
Ti Book HDD Flex Cable Woes
PowerBook G4 & iBook G4
I recently got a PowerBook G4 A1025 in a lot that I am refurbing. The machine generally seems to run beautifully and is in pretty good...
Oct 30, 2025
indigo_k
iMac G4 constantly crashing/kernel panics
@jeffburg - I think you might be on track with the RAM suggestion. I removed one of the two chips I installed, and it's been running...
Oct 30, 2025
T
ThePhage
Thanks for the clarification and history, Rob_A. I've updated the User Guide appropriately.
Oct 30, 2025
I have tried diopters. That might work if the focus was almost in, it wasn't close with the above lens. I expected the sensor needs to...
Oct 30, 2025
darvil
Floppy drive head ribbon cable broken
Hello! Here goes an update after a long while; I was able to find a MP-F75W-11G on eBay for cheap. It was quite rusty but luckily the...
Oct 30, 2025
R
Rob_A
A small addendum to ThePhage's splendid User's Guide to 0dan0's Enhanced Firmware... In the FrameRate section I read "8mm film is 16...
Oct 30, 2025
R
Rob_A
I've been collecting my thoughts for some comments and queries about the updated firmware and use of the Kodak Reels in general, but...
Oct 30, 2025
It was set to 256 colors. I did change it to thousands of colors and to grayscale to see it if got better, but it didn’t seem to. I...
Oct 30, 2025
What is 28F020 command 30h? I don't see it in the Intel or AMD data sheets. Do flashable ROM SIMMs have extra logic to catch this command?
Oct 30, 2025
What color depth is being used in the photo? Change it to B&W so we can see which VRAM data lines are broken.
Oct 30, 2025
The 650 definitely wouldn’t boot with two of the F245s removed! I’ll try to run through the traces tonight. Thanks!
Oct 30, 2025
