Cracked Hinge on Mac Portable
Oh, wow! Yes, that is significant. Ease of disassembly, but difficult to replace/repair that complicated of a piece as a whole. :mad:
Nov 20, 2025
Desktop G3 Zip/Jaz bezel
Here is version 2 based on those measurements. Someone will have to print and test to see if adjustment is needed. Because you can see...
Nov 20, 2025
You mean recreate the entire main structural piece? It's a pretty complex frame, as you can see at right in tech knight's video at...
Nov 20, 2025
This makes me wonder if the ribs are actually structurally significant, or if the design was to just reduce plastic quatity and weight...
Nov 20, 2025
In my review of the BABY FACE, oh yes. I had a lot of noise on the 12V rail shortly after power on, such that it even appeared on the...
Nov 20, 2025
My experience with sub 1.0mm drill bits isn't good. They almost break when I look at them! :) Seriously, they aren't strong, and...
Nov 20, 2025
N
NJRoadfan
Not every file has a resource fork (this is certainly the case for Apple II files stored on Macintosh volumes) and the resource fork...
Nov 20, 2025
muse
Don't know if I'd ever want to use one of those replacements. They seem quite noisy. 80mVp-p for the 60-5 module 120mVp-p for the...
Nov 20, 2025
annawat4
Colour classic learnings of the day
As far as I know, on updated Mystic Color Classics, the bus error can be fixed. If you correctly configure the analog board ID pins.
Nov 20, 2025
FinderInfo and ResourceFork are two separate file system objects so they can have different data. xattr -lpx com.apple.FinderInfo...
Nov 20, 2025
Do 0.8 mm drill bits like bending forces or are they brittle in the non-vertical direction? How wide are the ribs? How long are the...
Nov 20, 2025
