S
Scout
I did not realize it was a two piece deal. I just took one apart. That helps a lot, just knowing that. Although I am missing one of...
Nov 20, 2025
thecloud
Thanks, hopefully I get it now. You're saying that some of the basic metadata (like tbxi/chrp type and creator in your example) is...
Nov 20, 2025
MeTheMac
eMate battery tray
Woah! When I get my new Bambu Lab I'm going to print this. My janky batteries will finally be able to rest.
Nov 20, 2025
RolandJuno
eMate battery tray
3D Printing
I created a printable battery tray for the eMate to hold 4 x AA NiMH batteries. Since I use the eMate occasionally, I wanted something...
Nov 20, 2025
2008 Unibody MacBook Pro Linux gpu issues
I found this thread on the arch forum with a guy having similar issues with the nvidia driver and 08 mbp. Doesn't look like he perfectly...
Nov 20, 2025
Cracked Hinge on Mac Portable
Oh, wow! Yes, that is significant. Ease of disassembly, but difficult to replace/repair that complicated of a piece as a whole. :mad:
Nov 20, 2025
Desktop G3 Zip/Jaz bezel
Here is version 2 based on those measurements. Someone will have to print and test to see if adjustment is needed. Because you can see...
Nov 20, 2025
You mean recreate the entire main structural piece? It's a pretty complex frame, as you can see at right in tech knight's video at...
Nov 20, 2025
This makes me wonder if the ribs are actually structurally significant, or if the design was to just reduce plastic quatity and weight...
Nov 20, 2025
In my review of the BABY FACE, oh yes. I had a lot of noise on the 12V rail shortly after power on, such that it even appeared on the...
Nov 20, 2025
My experience with sub 1.0mm drill bits isn't good. They almost break when I look at them! :) Seriously, they aren't strong, and...
Nov 20, 2025
