  • JDW
    JDW replied to the thread Cracked Hinge on Mac Portable.
    If you look closely, the tips are all sharp hooks... https://www.amazon.com/Plaque-Remover-Cleaning-Adjustable-Cleaner/dp/B0F1K99FCR...
  • phunguss
    phunguss replied to the thread Cracked Hinge on Mac Portable.
    I wonder if the mentioned dental scaler would work for removing this metallic covering?
  • JDW
    Just had a new idea to supplement what my current plan. You can see on my Amazon order that I have a 2.0mm thick transparent...
  • JDW
    LOL. I guess the lack of comments are basically telling me: "Go for it, James. We're waiting with bated breath to see if it works out...
  • muse
    muse replied to the thread Modern power supply for se/se30?.
    You'll need to drill a hole with a small drill bit and then expose the copper with a blade either side for the solder to adhere to...
  • JDW
    Okay, folks. After many hours of talking to ChatGPT and searching on my own, I've changed my mind about using screws or drilling holes...
  • _nec6678
    Update! I've installed GammaCorrector 1.1.1 from the Macintosh Garden, and it has worked really well to get rid of the green tint! In...
  • thecloud
    You can have this functionality without having StuffIt Deluxe 16 installed. Save the following into a file named "Create StuffIt...
  • MeTheMac
    MeTheMac replied to the thread Cracked Hinge on Mac Portable.
    Oops quoted wrong . My bad!!! Thanks for the in-depth answer anyway, dont worry about it. Thx
  • JDW
    You quoted the part of my earlier post where I was talking about JB Weld, so I assume you must be asking if JB Weld will stick onto the...
