N
NJRoadfan
The STB Horizon+ is a generic Cirrus Logic CL-GD5430 based card. That happens to be the same chipset hypervisors like QEMU have support for.
Tuesday at 12:00 PM
Cracked Hinge on Mac Portable
Okay, friends. I have test results for you. Here is a closeup of the bubbles again, this time shot from the bottom of the...
Tuesday at 11:54 AM
The GitHub points to a wiki and a Discord. We can answer all questions in the Discord. DingusPPC is a work in progress so lots of stuff...
Tuesday at 10:16 AM
V
Vogone
LibreSSL and OpenSSH on Mac OS X 10.5 Leopard?
Thank you both very much! Both ssheven and Dropbear seem to be good options if there are problems with LibreSSL and OpenSSH. Knowing...
Tuesday at 8:31 AM
For the 47uf caps in the above mentioned Console5 kit for the SE/30 it contains 20V rated solid tantalums with the exception of c3, c4...
Tuesday at 4:56 AM
A
ArjenCNX
Maybe you are right, still, if we want to prevent stresses from building up, gluing is still best, this will need surface area to be...
Tuesday at 4:33 AM
A
ArjenCNX
I generally measure those buffer caps, and its exceedingly rare for them to fail, you can very likely re-use the old one. (that is my...
Tuesday at 4:30 AM
I don't concern myself with the failure mode of SOLID tantalum capacitors because I understand that most every manufacturer of those has...
Tuesday at 4:24 AM
