Anyone with a serial connection to Open Firmware able to get PCI info using #50 ...
Nov 27, 2025
O
omega
Hi, I also have a device from EU. Try using firmware from #511 It works for me.
Nov 27, 2025
@Grandson did you also try Type A? I think if not Type A the screen with remain blank. Is this the first we have seen RODREELSEU on...
Nov 27, 2025
Cracked Hinge on Mac Portable
There appears to be some voids on the underside of the subframe assembly (shown in this image on the left side) that could be filled in...
Nov 27, 2025
chuma
Old resistive touchscreen responds, but won't calibrate
Soldering and Repair
I recently acquired what seems to be a real unicorn of a device, a Sharp PT-9000 tablet computer, circa 1994. It's a chunky tablet...
Nov 26, 2025
G
Grandson
Yes, that's right, fishgee, it's a model purchased in the EU. I've now tried various firmware versions, including the ones without the...
Nov 26, 2025
T-Man
Apple Cube G4 Graphics glitch
It was just the video card, switch out some faceplates cards etc and found a working AGP ATI 3d with no glitches
Nov 26, 2025
Stephen
I am envisioning a perfectly form fitting bracket which is both epoxied and bolted into place — ideally, this will spread the load over...
Nov 26, 2025
@Grandson Try the original firmware from https://mac84.net/8mmlookup/ If that doesn't work, either the unit has failed (return) or...
Nov 26, 2025
