techknight
Cracked Hinge on Mac Portable
Very. I have run into it multiple times, and its because the hinges get stiff. 2 reasons. the hinge plastics shrink a bit, causing the...
Dec 2, 2025
techknight
Backlit Portable 5126 — Is your backlight this dim?
That backlight level is normal from what I have seen. Mine is like that, all of the ones I have worked on are like that. Flickering is...
Dec 2, 2025
Restore original Type B firmware, and return that unit as it seems just broken. Likely not a firmware issue as no one else has reported...
Dec 2, 2025
Does it say "V2.0" on the back, or only in the About screen? If the back looks like this: it will be pretty safe to try either Type C...
Dec 2, 2025
Trying to ressurect a Power Macintosh 9600/350
It doesn't damage the RAM to do that. The ANS is the same way and I routinely do a "double reboot" to skip the Long RAM test, which on...
Dec 2, 2025
Xanadude
Hey all! I’m not as technically inclined with all the code stuff in the firmware I read here. So I was wondering if I may ask for help...
Dec 2, 2025
T
ThePhage
I messaged you a link to a recent capture file that potentially demonstrates this. (7.1.1, model C, Super8, lens mod)
Dec 2, 2025
mmu_man
HowTo break apart and glue back plastic welded cases
Addendum on the Apple bricks (like, for the Portable and early PowerBook models), because I forgot again for the Portable: These are...
Dec 2, 2025
G
Grandson
Hello 0dan0, I have also tested the v7.2 firmware B. The boot logo appears clearly visible, but unfortunately all function keys are...
Dec 2, 2025
ftech
I can also add that if you force reboot the Mac during the RAM test (Ctrl Cmd Power) it won't proceed with the RAM test on the second...
Dec 2, 2025
Anyway... As I mentioned in the video I posted about a half hour ago, the little piece of plastic that looks like a latch of some sort...
Dec 2, 2025
Holy cow, I just noticed that Jason has a cracked right hinge holder too! Have a close look at his ribs, which are mostly missing in...
Dec 2, 2025
