F
Federico
Mmmh, mine is grinding gravel as well, from time to time. I'll try and grease it a bit too.
Dec 6, 2025
PowerBook 100 & 170 owners
PowerBook 100: 25 mm PowerBook 170: 30 mm
Dec 6, 2025
@T-Man Can you measure the ball diameter of your PB170's trackball? @David Cook Can you measure the ball diameter of your PB100's...
Dec 6, 2025
I had wound the focus until tight, but it wasn't yet perfectly in focus, need to more threads to turn. Nothing to do with the unit...
Dec 6, 2025
S
sheider
@0dan0 I also have a type C unit that I intend to lens-modify using the recommended 12mm lens from RMA Electronics (ordered and shipped...
Dec 6, 2025
H
hasi
Sensationell! Ich habe gerade ein paar Minuten Super 8 mm Film mit der A 7.4 Firmware eingescannt. Dies mit folgenden Werten: WB...
Dec 6, 2025
Eric's Edge
CodeWarrior
Arena memory management
Interesting concept. I'll have to try it out sometime. I'm working on a Wildcard Translator resource for HyperCard and learning...
Dec 6, 2025
As my Type C was stock, the resolution too low for me, I just lens modified my fourth scanner. This time I found I couldn't focus...
Dec 6, 2025
jimfrob
Trouble with Quadra 650 VRAM amount
Macintosh Quadra & Centris
My Quadra 650, which was severely battery bombed but amazingly still functions after quite a bit of cleaning, has two 512 KB VRAM SIMMs...
Dec 5, 2025
