Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
There are a lot of error messages I had suppressed with a NOP over the print console call. I don't remember if this is one of them...
Jan 24, 2026
jimfrob
PCjr picture going a bit funny
@phunguss I only have the one PCjr and the one PCjr display, and the proprietary connector means I can't try the display on another...
Jan 24, 2026
videodoctor
Ok, thanks for providing the source code for the RBN utilities, @0dan0. Indeed, the new command works and stops the motor! mem w...
Jan 24, 2026
Macintosh LCII failure
It is likely a cold solder joint. With thermal expansion, the connection gets broken. Lead free solder is usually the culprit, but I...
Jan 24, 2026
The code dev stuff could scare some away, but I always ported my findings in the main thread, just in case someone can learn from it...
Jan 24, 2026
videodoctor
Thanks 0dan0! I ran that mem command, and the motor did not stop. To be clear, the BIN you provided is your code update for the motor...
Jan 24, 2026
For recent US purchasers from Amazon, what serial numbers are you getting? H2825, D2825 or something else?
Jan 24, 2026
Yes, you can make Linux versions, I could potential use that too. Here is the source, I should forked the original and offered patches.
Jan 24, 2026
iBookSpeedster88
The following happened in November, so you all are now caught up with some of the more interesting things I did with my PowerPC Macs...
Jan 24, 2026
Any interest in Palm Pilots?
Separate URL: https://retro.tinkerdifferent.com/
Jan 24, 2026
videodoctor
As I continue work to find the AE hook to run 0dan0's custom code, I wanted to share my current bash script to update 0dan0's freed up...
Jan 24, 2026
videodoctor
I've done a lot of video compression with my professional work, and I use ffmpeg regularly. YouTube is going to recompress anything you...
Jan 24, 2026
Finally - A NeXT Computer (Cube)
So, I just recapped the logic board (it looked like someone had recapped, but the surface mount caps were poorly done, and I wanted to...
Jan 24, 2026
I
indibil
I'm updating my previous post, as I didn't have much time yesterday and wasn't fully aware of everything. Today I tried a "modern" PSU...
Jan 24, 2026
