clicking here
svenvendetta
Marchintosh 2024: Overclocking a Centris 650
Centris 650 was my very first Mac... a lot of great memories of having that machine and biggest purchase of my life at the time. Thanks...
Jan 24, 2026
videodoctor
In my hunt for the auto exposure function/hook in Ghidra in Firmware D, I found this function. The most interesting bit is at the end...
Jan 24, 2026
RetroViator
Mac IIsi Repairathon
Bravo is Beautiful Bravo is the system I've worked on the longest (technically, I started working on it in 2021), and it is finally good...
Jan 24, 2026
T
ThePhage
Like you, I am relatively new to Davinci Resolve (DR), however I've had semi-professional experience (and a lot of amateur/hobby...
Jan 24, 2026
T
ThePhage
My 2 cents here: feel free to continue sharing the technical info here in thread. While you two are engaging quite a bit above my head...
Jan 24, 2026
There are a lot of error messages I had suppressed with a NOP over the print console call. I don't remember if this is one of them...
Jan 24, 2026
jimfrob
PCjr picture going a bit funny
@phunguss I only have the one PCjr and the one PCjr display, and the proprietary connector means I can't try the display on another...
Jan 24, 2026
videodoctor
Ok, thanks for providing the source code for the RBN utilities, @0dan0. Indeed, the new command works and stops the motor! mem w...
Jan 24, 2026
Macintosh LCII failure
It is likely a cold solder joint. With thermal expansion, the connection gets broken. Lead free solder is usually the culprit, but I...
Jan 24, 2026
The code dev stuff could scare some away, but I always ported my findings in the main thread, just in case someone can learn from it...
Jan 24, 2026
videodoctor
Thanks 0dan0! I ran that mem command, and the motor did not stop. To be clear, the BIN you provided is your code update for the motor...
Jan 24, 2026
For recent US purchasers from Amazon, what serial numbers are you getting? H2825, D2825 or something else?
Jan 24, 2026
Yes, you can make Linux versions, I could potential use that too. Here is the source, I should forked the original and offered patches.
Jan 24, 2026
iBookSpeedster88
The following happened in November, so you all are now caught up with some of the more interesting things I did with my PowerPC Macs...
Jan 24, 2026
