Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
videodoctor
Where should I add prints to the code? As I don't know what you've added or where, I'd need some guidance from you on that, @0dan0. I...
Jan 26, 2026
RetroViator
Mac IIsi Repairathon
Charlie is Copacetic Charlie was working well after the recap, except it would not properly shutdown with Caymac's Power Up IIusi...
Jan 26, 2026
To be this wide, this is either downgraded the lens (even wider) or they have following this development and a planing a future lens swap.
Jan 26, 2026
S
sheider
Perhaps they also upgraded the lens in Type D units? And/or the stock Type D firmware has been modified from A-C's to capture a wider FOV?
Jan 26, 2026
That is weirdly wide for a stock lens and unmodified firmware.
Jan 26, 2026
Day 23-25 Misc Stuff I ordered some drive belts, and they arrived, so I was able to piece back together the broken SCSI cdrom drive. I...
Jan 26, 2026
videodoctor
As I'm new to the community, I'm not sure if there's a documented process for doing a full overscan, but I re-installed stock firmware D...
Jan 26, 2026
T
Upgrading IIsi onboard RAM to 4MB
There are four things that come to mind when shopping for that kind of part: 1) Is the shop reputable. IOW, will you get the part...
Jan 26, 2026
zezba9000
Hi, I have a couple IIsi systems (4 actually). I'm trying to validate and source/buy some new modules for these systems but I'm hoping...
Jan 25, 2026
I think so. hist.c should not be called before the new New Preview Res code
Jan 25, 2026
AR0330 2.2um pixels OS04D 2.0um pixels I'm assuming the same lens. Please do a full overscan, need to see the sprockets. The smaller...
Jan 25, 2026
videodoctor
I’ll test again, but that’s where the process froze. We’ll get this solved! Did you determine all four type 4 variables for your host.c?
Jan 25, 2026
